fuel no start - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-17-2009, 12:15 AM   #1 (permalink)
84darknight's Avatar
fuel no start
I got a problem my truck gets fuel but it wont start it cranks and everything I havent tried checking the timing yet but and i just put a block off kit in place of the EGR system cause i dont have an emissions to worry about. Any Ideas
84darknight is offline
Old 10-17-2009, 07:56 AM   #2 (permalink)
aalan's Avatar
Quote:
I think the reason no one is responding here is that if they are like me. Then they are confused.
It won't start but it cranks and everything? What?
I havn't tried checking the timing yet? How is that possable if it won't start?
I'm not bashing here. I'm just saying that if you were to be more specific you probably would get more help.
__________________
84 4runner
22r carb.
One Owner
aalan is offline
Old 10-18-2009, 10:13 AM   #3 (permalink)
my-4x4's Avatar
Do you have spark?
__________________
-'87 4x4 22r fairly stock.
-Thrush glasspack
-Hurculined cab floor
-SR5 Gauge swap
-'84 4x4 22r STOCK
-32x11.5 BFG M/T
-Magnaflow exhaust
USAF Confinement Officer
my-4x4 is offline
Old 10-19-2009, 10:24 AM   #4 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
You're sure it's getting fuel? There's fuel visible in the sight glass on the carb float bowl? (it is carb'd right?)
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 10-19-2009, 10:42 AM   #5 (permalink)
Need some details here.
Carbed?
Did it start before?
Fuel pressure good just before entering the carb, can hook up fuel press. gauge to check. (if bad then maybe pump, but would check fuel filter first)
If you have spark and it started before then it may be your electric choke too. I've had that problem.
Some of these questions should allow the community to help you out quite a bit.
live4soccer7 is offline
Old 10-20-2009, 04:02 PM   #6 (permalink)
It ran before just fine i just put a block off kit for my emission system the wires on the electric choke are a little bad i made the mistake of not labeling the wires so when i chooked it back up they may be backwards but i tried it all ways. I got fuel pressure when i got the truck the guy said the carb need to be rebuilt that was about a year ago. and the book cant reall help at all and i tried to find pics of carbs like it to see maybe if i can get the wries hooked up back to the right way. So i dont know if its as easy as just get a rebuild kit or what
Old 10-20-2009, 09:59 PM   #7 (permalink)
my-4x4's Avatar
You can get a rebuild kit for around $40 at parts store, and I'll post a breakdown pic of the 22R Carb (factory) when I get home on my cpu
__________________
-Thrush glasspack
-SR5 Gauge swap
-'84 4x4 22r STOCK
-32x11.5 BFG M/T
-Magnaflow exhaust
my-4x4 is offline
Old 10-21-2009, 04:30 PM   #8 (permalink)
ok thanks any other ideas what it may be other than the rebulit or the kit is all it would need
Old 10-22-2009, 06:32 AM   #9 (permalink)
83
83's Avatar
Sure seems like it's got to be something with how you put things back together after the block-off plates, no? I know if my truck was running fine, then I did something, now it doesn't, I'd just go back through what I did and make sure I put everything back together right...check out your manual (really should have one if you don't). I just wouldn't mess with anything except what you played around with to do the blockoff plates.
Why would it be timing if it was fine before you messed with the egr? I know my truck is slightly different (83), but when I messed with my egr, I went nowhere near timing stuff. All I needed to do on my truck was take the air filter housing off...so I certaintly wouldn't be thinking it's anything except what you messed with to do the block off plates.
__________________
Zach
'83 Shortbed 4x4
L52HD
Rebuilt & Mostly Stock
83 is offline
Old 10-22-2009, 10:47 AM   #10 (permalink)
yeah well i i did was put the block off kit on there and my EGR broke right in half and it was cheaper to put the block off kit on so i did that i didnt touch anything else
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
