front axle brake upgrades
so I have been searching over the sit for a few hours now and I cant find any threads about brake ungraded from stock front axles to something better. anyone have a link for one or some sort of cross over list?
1990-1995 Toyota 4Runner V6 calipers, pads, master cylinder, and brake booster
1985-1989 Toyota Landcruiser rotors
You'll have to clearance the splash shield for the bigger caliper. Also check clearance between the back of the wheel and the caliper.
i run a t100 dual-diaphram large diameter booster, it bolted right in, along with lc rotors and v6 calipers.
here is another variation, using the weaker single-diaphram large diameter booster, and t100 rotors/calipers: http://www.expeditionportal.com/foru...955#post849955
the numbers that are cast on the side of the calipers are important, for identifying what you have.
