Sign in using an external account
| 84-85 Trucks & 4Runners 2nd gen pickups and 1st gen 4Runners with solid front axles |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Extreme Negative Camber...
#2 (permalink) |
Personal
Sales Rating: (0)
Got pics?
Because camber would be caused by bent housing, bad trunnion bearings, bent spindle, bad wheel bearings, something like that. It looks like the top of the tire is either further out than the bottom of the tire or vice versa. Like older VW baja beetles, or some sand rails. Their back tires looked like a "V" when viewed from behind the vehicle. Improper toe would cause the tires to look like they are pointed in towards each other at the front of the vehicle(toed-in) or at the back of the tire(toed-out). Which exactly are you having? |
#3 (permalink) |
Personal
Sales Rating: (0)
haha I thought it was going to be a picture of some VIP car like this
But I would say go and get an alignment they can give you all the info you need. |
#4 (permalink) |
Personal
Sales Rating: (0)
[OP]
Hahaha, it pretty much looks like the pic above! Maybe not THAT extreme, but its pretty bad. If you were to look at it from the front, knowing that the camber is bad, you could visually notice it. The housing seems to be problem free, but there is a bit of fluid leaking from what ive told is probably a "bad axle seal". Could that be the cause of the problem? I cant imagine it having THAT much effect on the camber. Either way, I intend on putting in some nice, beefy Marlin EcoSeals! From what I understand, toe-in (or out) can easily be adjusted by spinning the tie rod. Im curious if theres a simply point of adjustment like this to help fix my issue...
#5 (permalink) |
Personal
Sales Rating: (0)
If its in at the top, thats prob a bad trunnion bearing. Its possible axle housing or spindle or wheel bearing, but if you're certain those are ok, then trunnion bearing. The leaking could be a bad axle seal, but I would bet that the wipe seals are junk also. Get ahold of the Wabbit at Wab-Fab Offroad, and get a wipe seal, trunnion bearing,(knuckle rebuild kit) wheel bearing set and just rebuild both sides. Its very easy. Use the same shims under the bearing retainers that you take out. If the shims are chewed up, you should be able to get a close approx thickness from the old ones. The kits come with new shims. If you can do wheel bearings, you can rebuild the knuckle.
#6 (permalink) |
Personal
Sales Rating: (0)
__________________
'89 4runner,'73 BMW 2002,'98 KX250 * gone: '86 4runner, '87 4runner, '94 x-cab, '90 Mustang GT |
#8 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
#9 (permalink) |
Personal
Sales Rating: (0)
Start with going to get an alignment. Like stated by Jdogg. and if it doesnt help they will tell you what will.
__________________
1991 toyota pick-up 22re,K&N cold air, 2 inch BL and 33x12.5 inch Mud terrains. headman header to flowmaster. 83 toyota pickup (sold) Built 22R 5 in. trail gears in rear, rears up front, 2inch body lift 35x12.5r15 bfg muds Rhino lined paint job bobbed, flat bedded, snorkel |
#10 (permalink) |
Personal
Sales Rating: (0)
[OP]
kinda what im leaning towards doing, thanks for the input. i hate to spend the cash, but ive owned 2 first gens, guess i better get used to being broke again haha!
#11 (permalink) | |
Personal
Sales Rating: (2)
Quote:
- http://www.4crawler.com/4x4/CheapTri...html#Alignment
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#12 (permalink) |
Personal
Sales Rating: (0)
If it were mine, I would jack it up, get the tire up off the ground, grab the top and bottom of the tire and see if/where there is movement... An alignment shop will do the same thing, and offer to repair it for a healthy sum. Then they will prob find some other probs and tell you that its gonna kill you if you drive it without letting them repair it... and it might...
#13 (permalink) |
Personal
Sales Rating: (0)
is it possible that the knuckles were serviced previously and installed upside down???
#14 (permalink) |
Personal
Sales Rating: (0)
[OP]
Havent updated for a while, but figured I would fill anyone in that was genuinely interested in what was going on, or possibly having the same issue. Basically I ordered Marlins axle rebuild kit, figuring no matter what was wrong, it couldnt hurt to throw some new gaskets, seals, and bearings in. Well, when I got the passenger side torn apart I found the issue; the lower knuckle bearing was literally in hundreds of pieces! New bearings, gaskets, and seals in= no more steering issues or leaks! Thanks to everyones advice! I did indeed jack the front up and grab the tires, and there was a significant amount of play. I still cant believe Im alive today after seeing how bad the situation was! Also, for anyone thinking about doing knuckle work with no experience, Id say dive right in! Very straight forward, and the help of toyospearo's sticky and 4crawlers link (above) helped a ton!
#15 (permalink) |
Personal
Sales Rating: (0)
which marlin kit to get for axle
Ok trying to figure what kit to get there are 3 , one is just seals and gaskets for like 50.00 - the other is a servicce kit also for 99.00 and has bearings for the knuckle . and the other is super extreme price of 179.00
So if anyone could let me know out of the three witch one I should get for the rebuild prob,the 99.00with bearings I assume . Thanks |
#16 (permalink) |
Personal
Sales Rating: (0)
Awfully aggressive first post there chief.
Awfully funny too though... ![]() jswizz...wrong thread for that. This is for you.
__________________
"Ya gotta love 'em, 'cuz it's illegal ta kill 'em." - Ron Shirley from Lizard Lick Towing & Recovery of NC. I'm Cuckoo For YOTA Trucks! Putting theTECH inYOTATECH since 2007 |
#17 (permalink) |
Personal
Sales Rating: (0)
EXtreme badd camber / knuckle bearings , etc....
Yeah how is it the wrong thread , talking about axles right .and Marlin etc..break it down guys ! Driveallday back at you tough guy , you arent funny . :
#18 (permalink) |
Personal
Sales Rating: (0)
Depends on if you need just knuckle bearings or wheel bearings as well. The 179.00 kit has trunnions bearings, seals, wipers, felts, and wheel bearings and seals. If you need just trunnions, get the 99.00 kit.
#19 (permalink) |
Personal
Sales Rating: (0)
OK thanks rockblock . Here's another question staying with the same theme!
I just did my wheel bearings 2 days ago and they feel loose again and I got some wobble its either both knuckle rebuild and bearings . I tightened them and bent over the tab to lock them in place and eveything ? thanks in advance anyone. |
#20 (permalink) |
Personal
Sales Rating: (0)
First thing you should do is determine where the looseness is... 12 and 6 o'clock, or 9 and 3 o'clock? And once you figure that out, research if others have had this problem, read through their threads completely, if you are still at a complete loss, then you should start a new thread and we can figure it out.
We have hijacked this thread enough. |
| Tags |
| 91, bad, bearing, camber, crazy, extreme, front, horrible, mustang, negative, pickup, toyota, trunnion, tube, vip |
