Doing the SR-5 Gauge Cluster Swap... HOW TO with pictures. - Page 7 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-15-2009, 08:47 AM   #151 (permalink)
I cannot do it with my fingers alone, getting the knives
Quote:
Originally Posted by Secret237 View Post
Ok, trying now
Secret237 is offline
Old 03-15-2009, 08:50 AM   #152 (permalink)
4Crawler's Avatar
From the 4x4wire post:
"Then I pulled the needles off with a pair of spoons under the base of the needle"
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 03-15-2009, 09:05 AM   #153 (permalink)
I am bending the metal shaft ... still not off
Old 03-15-2009, 09:17 AM   #154 (permalink)
Ok, got the black plastic cap off, broke it of course, but I can fix that, I can fix anything !!
Still got to get that needle off though. Looks like splines on the shaft
Old 03-15-2009, 09:18 AM   #155 (permalink)
I am going to try heat in a min. here
Old 03-15-2009, 09:26 AM   #156 (permalink)
Got it, no heat, but it was the shaft that came out of the gauge !! The plastic needle is still on the splined shaft !!
Just poped off and hit me in the head ... I was actually scared of bending my knives.
I've probably broken it, but IDK, I think all I need to do is glue it all back together !! Gauge still seems to work, there is now a sharp pin like thing sticking just above the surface, the needle shaft was over, or around.
But at least I'm there, Thanks
Geeze ... laugh
Old 03-15-2009, 09:35 AM   #157 (permalink)
I'm now advancing my odometer, still going to take a while, it's at 180,000 miles now and I have to take it up to just over 308,000 ... most people would turn it back !!!
I guess I'm a fool, it's just I put all those 308,000 miles on myself and I just don't want to go back.
Old 03-15-2009, 09:38 AM   #158 (permalink)
I figured if I had used a drill motor to run it up it would have taken over 80 days at 60 miles per hour 24/7 I would have bruned up my drill motor !!
This is easier ??
Laugh
Old 03-15-2009, 09:43 AM   #159 (permalink)
I'm now able to advance it at over 1 mile a second ( more like a mile every .75 sec. )
Still will take over 26 hours at this rate !!
Laugh, maybe I'll get faster
Old 03-15-2009, 09:56 AM   #160 (permalink)
I'm able to go about 125 miles a min. which is 7,500 miles per hour
Not bad for a 4 cly.
Old 03-15-2009, 10:27 AM   #161 (permalink)
15,000 miles per hour !!!
Old 03-23-2009, 03:13 PM   #162 (permalink)
Quote:
Originally Posted by DudeBud View Post
there sould be a green plug right off of the coil igniter that would be for your tach and then on the back of the cluster there are 3 screws in a line and one of them is what you need to hook the wire too sorry i cant recall what one it is
I wouldn't have been able to get mine working without this piece of advice right here. So thanks a lot for the help. BTW... on mine it was the screw on the left.
__________________
97 Ford Explorer 4X4 ( Daily Driver)
85 Toyota Pick-Up 4X4 (Rock Krawler)
88 Toyota Pick-Up 4X4 (SOLD)
elshamrocko is offline
Old 04-02-2009, 09:25 AM   #163 (permalink)
I read all 7 pages of this post, maybe I skipped something not sure, but can somebody tell me what I need to do to make an SR5 cluster from a '95 Runner V6 Auto work in my '92 Pickup V6 5spd?
I've seen it mentioned but haven't seen exactly what the problem going from Auto to Manual is as far as the gauges. Somebody mentioned the OD off light and the ECT light on the dash of an Auto cluster, but wouldn't they just stay off if I put the cluster on a Manual?
Is there any other issues with going from and Auto to Manual other than these lights, and if so what are they and what are the fixes?
Thanks.
mmcpeck is offline
Old 04-02-2009, 09:51 AM   #164 (permalink)
Windsor's Avatar
My advice is to start a thread in the appropriate forum with your question.
You'll get more attention from those who might know the answer -- the instrument clusters are quite different between 84/85 and 92/95.
__________________
'87 T4R Deluxe, mall crawler
every non-SR5 option installed (sans AT), as well as:
* Cruise Control (dealer installed)
* Michelin LTX A/T2 31s on 1st-gen alloy rims
* SmittyBilt granny step bar
* SR5 Instrument Cluster
Windsor is offline
Old 04-02-2009, 08:16 PM   #165 (permalink)
Yup did that Windsor, what I got was a link to this post, not even sure this post should be in this forum. So I read 7 pages of great information that answered almost all of my questions, except the Auto tranny question.
To be honest it never even occured to me that there would any difference at all...still not sure what difference a tranny would make to a Tach, but I saw it mentioned and just wanted to check before I went and got one out of an Auto truck.
Thanks.
mmcpeck is offline
Old 04-17-2009, 06:49 PM   #166 (permalink)
escodan760's Avatar
sr5 guage swap
i did this swap in my 85 4runner, it was all plug and play. not sure of the fuel yet, just had to clean the tank, it was sitting for two years, also replaced the fuel pump inside, just got it started today. onlky a couple of gallons in there so we will see
escodan760 is offline
Old 05-10-2009, 10:36 AM   #167 (permalink)
chuntr's Avatar
Quote:
Originally Posted by deserthound View Post
There are differences between the SR5 dash on a manual trans vs. auto trans vehicle. These are the changes I had to do to get a manual SR5 cluster to work in my DLX Auto 4runner dash. Both vehicles were 22RE, '86 models, mine a 4runner, donor a pickup.
I recently had to do the opposite, which I haven't seen documented elsewhere on here. I have an 88 5 speed and I just put in an SR5 cluster from an 86 automatic. both V6 trucks. its almost the reverse of the above but it's a little simpler. my truck is EFI so it was pre-wired for the tachometer. otherwise you can run the wire from your coil to the A5 terminal.
connectors and wires are labeled on the dash cluster where they plug in. here are the steps for putting an auto cluster in a dash wired for a manual:
move yellow/black wire from A3 to A2 (oil light/guage)
move purple wire from A5 to A4 (check engine light)
move black wire from A6 to A5 (tach lead)
move yellow/red wire from C5 to C6 (fuel gauge)
move brown wire from C4 to C5 (fuel gauge)
I am not 100% on the fuel gauge wiring because mine didn't work before the swap and still doesn't. the brown wire was brown/black on the auto cluster but i traced everything out on both clusters and they seem to go to the same places. everything else seems to work fine.
chuntr is offline
Old 05-23-2009, 09:50 PM   #168 (permalink)
FZRDude's Avatar
I have a turbo cluster, unknown year/model. Am I barking up the wrong tree trying to put this into a 85 carbed, auto, truck?
FZRDude is offline
Old 05-25-2009, 06:20 PM   #169 (permalink)
shore.runner's Avatar
I just did this and...
I fried the oil gauge ( oops) , my tach doesnt work, and my fuel gauge doesnt work....
I already read all this stuff about the tach, i took this cluster out of my parts truck, which it worked on, and it didnt have that little green thing on the coil.
Im so confused!?!
I want my gas gauge to work too, any help ?
__________________
88 4Runner 22RE, 5Speed Swap Aisin OEM Clutch--NGK Wires-- Hella H4 e-Code Conversion -- 100/80W Xenon Blue Bulbs -- IPF 986 100W driving Lamps -- Supra AFM W/Custom 3'' Intake --Trail Gear Rear Bumper-- XMSAT W/ Alpine Deck-- LCE Header and Exhaust on its way.. 270xxxkm
shore.runner is offline
Old 11-03-2009, 10:06 AM   #170 (permalink)
minimudder's Avatar
Send a message via Yahoo to minimudder
Thank you fot the great write-up.
minimudder is offline
Old 11-03-2009, 03:47 PM   #171 (permalink)
theBurlyone's Avatar
Quote:
Originally Posted by Ilovemountains View Post
I had to find one for a V6 with the automatic to make it work in my 88. I had to buy the sending unit and went ahead and installed new bulbs while I had it out. OH dont buy the autozone brand bulbs, they do not last! My tach works great. My temp gauge is goofy though it doesnt register till the engine warms up, then goes right to the middle!
I have an 85 SR5, so in other words it came with that cluster stock. My point is that my temp gauge does that on my truck as well so I think that might be normal.
theBurlyone is offline
Old 11-03-2009, 06:45 PM   #172 (permalink)
just did my cluster had to run wire for tach but cant get temp to work with new cluster any idea how to fix
dorado23 is offline
Tags
1984, 1987, 4runner, 88, cluster, corolla, gauge, guage, oil, picture, pressure, remove, sr5, swap, switch, temp, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
sr5 gauge cluster toy power The Classifieds GraveYard 2 03-20-2007 01:37 PM
gauge cluster question drpdmazda 86-95 Trucks & 4Runners 3 01-03-2007 02:07 AM
SR-5 Fuel Gauge toyguy1986 95.5-2004 Tacomas & 96-2002 4Runners 5 07-21-2005 04:49 AM
Instrument gauge cluster Toys-R-Us Off Topic Talk 5 05-25-2005 11:27 PM
2009 InternetBrands, Inc.
