Cut fan shroud in half? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-18-2009, 11:26 AM   #1 (permalink)
84YotaBuck's Avatar
Anyone ever cut one in half horizontally to make it easier to remove? With it stock you have to take the clutch fan off which can be a pain, would make everything easier if you could take the shroud out first, then you'd have more room to get the clutch fan off, or alternator out. I'm thinking, cut in half horizontally, you'd have 2 bolts holding each half on. If you did it vertically, the way the bolts are the center may flex out, but horizontally I would think it would be allright.
__________________
84 Extended cab
84YotaBuck is offline
Old 12-18-2009, 11:31 AM   #2 (permalink)
TOYOTA 1's Avatar
iirc the 3rd gens are already like that from the factory, not sure though.
__________________
91 Toyota "built not bought"
Quote:
Originally Posted by BigBluePile View Post
I just bought a Toyota and I don't have any tools or any kind of area to work on it with and I'm wanting to drop in a V8 and clear 38's but I don't have any money and do I need to lift this if so what kind of lift and what do you recommend also I'm not sure if all terrains will work in mud is there another kind I have some rims that should work but they came off a yugo so is the bolt pattern the same...
TOYOTA 1 is offline
Old 12-18-2009, 12:11 PM   #3 (permalink)
4Crawler's Avatar
Quote:
Just pull the lower part of the shroud off:
- http://www.4crawler.com/4x4/ForSale/...ToyotaRadiator
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 12-18-2009, 12:45 PM   #4 (permalink)
84YotaBuck's Avatar
would love to, but mine is all one piece. Just finished cutting it in half, looks like it'll work like a champ!
__________________
84 Extended cab
Tags
fan, make, shroud
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
