Sign in using an external account
| 84-85 Trucks & 4Runners 2nd gen pickups and 1st gen 4Runners with solid front axles |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Crack in Trans Case...
__________________
91 PU X-Cab, 3.0 V6, 3" lift, 4.88s, Detroit EZ in the front, 32" BFG A/T KO's. 85 4runner, 22REC, 4" lift, 4.88s, Detroit F/R, 32" BFG KM2's, TG Sliders and Rear Bumper. |
#2 (permalink) |
Personal
Sales Rating: (0)
Weld it for sure. I would probably weld a sleeve on it instead of just welding the crack but I tend to over-do things.
__________________
1990 Xtra Cab 4x4 3VZ-E/R150F Swap ----- 1980 Std Cab 4x2 20R/W50 |
#3 (permalink) |
Personal
Sales Rating: (2)
Some tips below:
- http://www.pirate4x4.com/forum/showthread.php?t=1041926 You might try draining the case and clean the crack well and then using something like JB Weld in the crack followed by some sort of ring or clamp over the outside to hold the crack closed. Best would be if you can find some sort of steel ring that would be a jam fit over the round part there.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler; 02-03-2012 at 09:34 AM. |
#4 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thanks for the replies. Hard to believe I'm going to have to replace the case for that little bs crack. The repairs seem like just as much work as replacing the case. I don't have access to a TIG welder, so I would have to take it in somewhere. Not sure how much that would cost.
__________________
#5 (permalink) |
Personal
Sales Rating: (1)
I have this exact same problem, I by no means half arse anything on my vehicle while fixing it, however this is what I did and how it has worked. Just keep in mind, I am purchansing a completely new T/C that is geared so this is why I went this route.
The crack is in the exact same spot, and as you have stated, It was there when purchased, I was informed about the crack. I DID use JB weld to cover the cranck after thouroghly cleaning it, scuff it up with some sand paper (lightly) and let it cure with the plug out. after that, I replaced the plug and washer. I have a very very minimal leak going still but not engough to ever really get on the case it self. This has held in place for 3.5 years with several T/C fluid changes in between. Not a permanent fix, but like I said before, I had plan to get a new case with gears when this one crapped out, it just hasn't yet!
__________________
87' 4runner-motor, tires, bumpers and a winch |
#6 (permalink) |
Personal
Sales Rating: (0)
If it were mine, I would clean it very well, de-grease it as well as possible, the dab some JB weld-type epoxy on it. I would find some sort of sleeve that just barely fit over that thread boss, then possibly have the sleeve welded to the bolt, so that when you tightend the bolt, the sleeve snugged over the boss. Or just sleeve it and let the bolt retain the sleeve.
| Tags |
| crack, trans, weld |
