YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 11-08-2006, 01:17 PM   #1 (permalink)
Rust in the vacuum lines(metal tubes) for '85 22RE EGR
Has anyone checked if their metal vacuum lines are rusted and blocked like mine are, twice now. I am wondering how moisture is getting in there. Now my EGR modulator isn't working the way it is supposed to(has water in it). According to the FSM with all hoses off I apply air to Q
and close P and R and air should come out of filter. Q is completely plugged no air passes at all through Q. New Modulator is $60 at autozone. Also my carbon canister is failing the FSM tests, I can't see how to disassemble it to clean it. It looks like the top should spin off but no. Any suggestions?
Does anyone else have a 22RE with plugged vacuum lines?
Hi I have tested the EGR system some more and what I need is a more detailed test of the EGR Modulator, is there one somewhere? The Fact Svc Man 's test was too limited. I can't figure out why the EGR valve is opening right away as I increase throttle instead of after 3500 rpm like it should. Thanks for all your help.
Pete
pcmentor is offline
Sponsored Links
To remove this ad, register today!
Old 11-08-2006, 06:41 PM   #2 (permalink)
myyota's Avatar
The only possible way i can see water getting into the metal vacuum lines is if one of the temperature operated vacuum valves has failed internally and water is somehow getting through the valve into the vacuum lines. (thats a guess on my part, i don`t know if its possible for that to happen).
Your charcoal canister doesn`t come a part for cleaning, if its bad it has to be replaced.
myyota is offline
Old 11-10-2006, 08:07 AM   #3 (permalink)
4Crawler's Avatar
I would also suspect the BVSV where the vacuum lines connect to under the throttle body. That seems to be the only place where coolant is involved with the EGR system.
Try using the FSM cleaning procedure for the cannister with compressed air. I did mine about 2 years ago and was amazed at the clouds of dust and what not that came out of mine.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Vacuum lines? raymeg 84-85 Trucks & 4Runners 0 04-02-2007 07:04 PM
red vacuum tubes linuxrunner 86-95 Trucks & 4Runners 4 08-10-2006 09:17 AM
vacuum lines j40joe Land Crusiers/full size SUVs 0 07-19-2006 06:48 PM
water in vacuum lines 81 flatty 86-95 Trucks & 4Runners 0 05-29-2006 05:29 PM
power steering and vacuum tubes r2xj 95.5-2004 Tacomas & 96-2002 4Runners 4 09-28-2004 11:55 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
