Chase rust or swap cab - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 03-16-2013, 01:56 PM   #1
Heres the deal I must bought a 1985 4wd pickup with what looks like replaced doors, maybe both fenders and hood. The cab has a lot of rust. A few holes coming through the floor. Under the mats, and down around the rocker panels.
I'm wondering if I should chase down and patch all the spots I can find or do a cab swap with a cab in better shape. Both will require lots of work. I have a shop with the tools to do either on. Just not sure, both seem like they would coast around the same amouant given that I would have to buy replacement panel/cab.
Just wanted some feed back anything is better then nothing. Also I would like truck to be used a daily drive more then anything.
The_hub is offline   Reply With Quote
Old 03-16-2013, 02:51 PM   #2
dakotawho's Avatar
Well if you choose to do a cab swap, terrys87 has done a few on yotas and is extremely helpful. I have also done one, its not that bad(only 17) just take your time and mark stuff. Also double and triple check you took off all wires. Terry has a list of the majority of the things you need to do in one of his build ups somewhere. Few threads bout cab swaps on here. Just search In my opinion though....rust is a battle you can't win..You fix one spot and it just moves to another.
dakotawho is offline   Reply With Quote
Old 03-16-2013, 03:44 PM   #3
Fossilized
Staff
dropzone's Avatar
Which one do you feel like doing?
I would do a cab swap but with out detailed pic$ hard to really say.
Like mentioned above make sure you unhook everything and mark all connections
dropzone is offline   Reply With Quote
Old 03-18-2013, 09:09 AM   #4
I will post pics asap. I have googled cab swap in just about every form and have been reading up on it for a good month. i personnel would like the cab swap as my cab in not in the best of shape.
Icentropy's $400 4runner build icentropy 86-95 Trucks & 4Runners 14 10-22-2016 10:24 PM
88 Pickup Transmission Swap mskalmus 86-95 Trucks & 4Runners 6 03-21-2016 12:41 PM
*SOLD* 1991 Toyota Pickup DLX 4x4 5 speed 165k, fresh motor,lifted,clean! $6150 GreatLakesGuy The Classifieds GraveYard 8 09-04-2015 10:27 AM
2nd gen with runner cage Steezy96yota 86-95 Trucks & 4Runners (Build-Up Section) 1 07-06-2015 11:00 AM
back of cab body plugs (1991 sr5) elwood73 86-95 Trucks & 4Runners 0 07-05-2015 08:07 AM
Tags
cab, chase, fix, panels, payment, repair, rocker, rust, rusted, rusty, sb, swap, swapping, time, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
