| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
charging circuit relay
__________________
drive it like you stole it! Last edited by va slim; 11-01-2009 at 02:32 PM. |
#2 (permalink) |
Super Moderator-Sponsoring Member
Staff
Charge and brake lights staying on indicates bad alternator.
www.ncttora.com/fsm for an 85 Factory Service Manual
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#3 (permalink) |
have you checked the fuse ?
#4 (permalink) |
relay is in the left kick panel, remove the trim panel and you'll see it.
__________________
- Brian 84 toy pickup mostly stock |
#5 (permalink) |
the charge fuse should be in the fuse box next to the battery. 7.5 amp ,it could be blown or not making good contact. i am assuming the truck is not charging .
#6 (permalink) |
Altenator wiring shorted out, after rewiring, the emergency brake and battery indicator lights stay on and the electric choke does not work. (battery is being charged, I've been driving like this for months!) All on same circuit by my book. Problem is "charging circuit relay", my problem is I can't find it. I've looked behind both kick panels and behind the glove box and undrer the hood. Book says it is marked "charging circuit relay" can you help? 1985 Toy p-u, gas, carb
__________________
drive it like you stole it! Last edited by va slim; 11-01-2009 at 02:25 PM. |
#7 (permalink) |
Just pulled mine out yesterday. Unscrew the driver side kick panel under the fuse box. the charging circuit relay is a gray 4 pin C shaped conection. Believe it is the the bottom right relay out of the 4 available spots. Hope this helps.
