Carburetor trouble shooting guide anyone? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-02-2009, 06:51 AM   #1 (permalink)
I fixed my timing issue, somehow got off one tooth while I was replacing the chain. Anyway she still shoots about a foot and a half of fire out of the exhaust at idle. I guess you could say it's running on the rich side. Also the fuel mileage is horrible, something seems to be allowing it to just dump fuel in. Sounds like a tractor at idle, but seems to run smoothly above that. Any ideas or ideas on how to track down the issue?
__________________
'84 4Runner
FOR SALE
More rust than horsepower, check it out http://www.yotatech.com/f115/dr-trev...thread-134004/
FOR SALE
Dr.Trevorkian is offline
Old 11-02-2009, 09:25 AM   #2 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
double check your valve adjustments. .008" intake / .012" exhaust, engine warmed up. .007" intake / .011" exhaust, engine cold.
also check the air-injection system / diverter valve.
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 11-03-2009, 11:16 PM   #3 (permalink)
XtraSlow_XtraCab's Avatar
Sounds like a maladjusted float. If the fuel bowl overflows, excess amounts of gasoline will literally drip into the intake. The reason it runs better at a higher RPM is because the motor is utilizing more gasoline and, thus, the fuel bowl never find the opportunity to fill up, over flow, and flood the motor.
__________________
Download your Factory Service manual HERE!
<I>I just finished BUILDING my own 4Runner because I'm too cheap to buy one... go ahead and call me crazy!</I>
1984 Toyota XtraCab 4x4 turned 4Runner in just ONE month.
XtraSlow_XtraCab is offline
Old 11-03-2009, 11:24 PM   #4 (permalink)
camo31"10.50"'s Avatar
my truck used to shoot a 4ft flame out of the tail pipe when i let off the gas...or let the engine do some breaking..
it would sounds like a shotgun...it was backfiring..and throwin a BIG flame..LOL
sometimes it would be as long as 6ft..lol..kinda scared some people..but other people thought it was BADA$$
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE
1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous
"Its still a toyota man.. Dont deprive it of its capabilities.."
"If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009
camo31"10.50" is offline
Old 11-09-2009, 06:05 PM   #5 (permalink)
Yeah it is definitely bad@$$, but 8mpg with a 4cyl and the terrible fumes associated with it are not. I did a little research and it sounds like maybe the diaphram in the accelerator pump is torn? About the float bowl, do I just need to take it apart to clean it?
By the way, from what I can remeber, it all went bad after doing some deep water mud running at mudfest in Okeechobee. After that it seemed to run pretty ty and also use too much fuel, but I didn't really run it that long because shortly thereafter it broke the timing chain guide and sat all summer. Anything associated with the mudding be causing this issue?
__________________
'84 4Runner
FOR SALE
FOR SALE
Tags
22r, diverter, engine, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
