brake upgrade on 1st gen runner? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-06-2009, 09:15 AM   #1 (permalink)
H8R
I've got an '85 4runner on 33x12.50R15's, newly installed 22re, with stock 4.10 gearing and a bad brake booster.
I already have a toyota dual brake booster, gm 1" master cylinder with toyota adapter, an adjustable brake proportioning valve and steel braided brake lines for an upgrade. I also have front calipers and rotors from a '95 T100 4wd.
My question is if the calipers and rotors I already have will work on my '85 4runner's solid axle or will I need a caliper bracket, wheel spacers, and/or larger wheels to clear the larger brakes or will they bolt right up?
H8R is offline
Old 11-06-2009, 09:27 AM   #2 (permalink)
Etype R's Avatar
You need 81+ Landcruiser brake rotors and V6 IFS calipers, not sure if the T100 calipers are the same. You will need different rotors though.
__________________
1985 Toyota 4Runner - Full SR5 package - 4 inch lift - 35" tires
Etype R is offline
Old 11-06-2009, 09:51 AM   #3 (permalink)
SpecialScottie's Avatar
Send a message via AIM to SpecialScottie
You might be able to use the T-100 rotors on the back
__________________
02 KLX300 Dual Sported (Daily Driver)
87 Turbo 4runner STOCK
85 4runner: Automatic marlin5.29 elocker rear end. Rola roof rack. 33" BFG KM2's Build Thread
87 4runner (parts)
95 4runner 2wd auto(sold)
SpecialScottie is offline
Old 11-06-2009, 09:53 AM   #4 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Probably need some wheel spacers to clear the bigger calipers or do a little grinding.
Why would you want to put GM on a Toyota? Get a FJ80 MC. You need sfa vented rotors and V6 IFS calipers.
Tons of info on Pirate and all over the place on this upgrade.
waskillywabbit is offline
Old 11-06-2009, 07:30 PM   #5 (permalink)
H8R
thanks for the replies.
I pulled a wheel off and compared the bolt pattern and size of the rotors. The bolt pattern on the rotors that I had was something like 6 x 5.0", so no biggie. I ordered some '85 landcruiser front rotors from advance auto for 23 bux each
H8R is offline
Tags
85, brake, toyota, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
