Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Brake upgrade?
I have a 85 stright axle under my truck and I am having a hard time stoping the 38's with the stock brakes that I have. So I was wondering if any of the V6 calipers would fit and mount the same way? Or is there a brake setup that a lot of guys are starting to use that works.
Thanks Kevin |
| Sponsored Links |
#2 (permalink) |
Staff
I am a bit fuzzy on exactley what you will need, but I know I put a '85 straight axle on my 4Runner and ended up running the V6 calipers on LC rotors. Not sure if you need the wheel spacers to clear everything. Ask WabFab if he sells the brake parts you need independently from the TG SAS kit.
You could also upgrade the rear brakes to discs: http://www.yotatech.com/f116/rear-disc-swap-107749/ With all that, your 38's will stop on a dime. ![]()
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Brake Upgrade, need opinions | DeathCougar | 86-95 Trucks & 4Runners | 81 | 05-12-2008 01:25 PM |
| Tundra brake upgrade | Delta Sierra | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 10-13-2007 09:39 PM |
| Brake Upgrade? | 69 1/2 Six PAck Bee | 86-95 Trucks & 4Runners | 0 | 10-05-2007 12:19 AM |
| Brake upgrade | 2wheelBLACKOUT | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 01-25-2006 04:34 PM |
| brake upgrade for 2wd | desert whomper | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 04-05-2005 11:34 AM |
