BJ spacers pros/cons
ok I just purchased the BJ spacer from trdparts4u.com and was just wondering what the pros and cons are from the guys already running it and if you have pics of your front setup with the spacer
con is you have to get a realighment , pro is you got more flex in the fround
con is you have to trim your upper control arm... pro is you get more height
Correct me if I'm wrong, but by turning the t-bar nut you are just essentially rotating the bar. So your not making the actual bar have more tension in it. The bounciness associated with cranked t-bars is actually from most of the shock going in to the c/vs, and over extended shocks? I have only seen this posted on this site once before, and it makes perfect sense to me. My turning that little nut on the bottom of the truck, you are just changing the degree the bar is rotated not making the t-bar increase its spring rate. so bj-spacers would not effect your ride if you relax the t-bars, because the ride height is still the same, keeping the suspension geometry the same.
Conversely, by putting in a bj spacer and relaxing the bar, you get more force transfered to the tbar, and less to the frame.
I'll look around later, but there is a whole thread explaining it. It takes a while to type.
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
08-23-2016 09:08 AM
JookUpVandetti
09-30-2015 08:58 AM
4runnerFireman
09-29-2015 06:24 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
09-27-2015 07:15 AM
