Sign in using an external account
| 84-85 Trucks & 4Runners 2nd gen pickups and 1st gen 4Runners with solid front axles |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
balance and blueprint?
#2 (permalink) |
Personal
Sales Rating: (1)
in this case .. it's all about the machine shop YOU choose .
ask them .
__________________
http://www.toyotafiberglass.com check out all of our builds in the VENDOR section 86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE CURRENT PROJECT 83 Trekker SR5 DONE June 2011 2WD fourm I frequent NEW Trekker forum |
#3 (permalink) |
Personal
Sales Rating: (0)
I don't know what ya mean by w/o boring, I'd say the ones that are in there are as big as they need to be.
My buddy has his bored .040 over. The rumor I've heard is the reasonable limit is .050. You can get a stroker crank, make it a 2.7L/2700cc. Check these guys out:http://custommachiningusa.com/index.html
__________________
We're sorry, theYOTATECH member you have reached is temporarily out of order or is no longer in service. Please feel free to ask our many other highly informed members about your problem. Or try using the search feature to find the appropriate information by yourself, and solve the issue on your own. Thank you for choosingYOTATECH. Good bye. I'm Cuckoo For YOTA Trucks! |
#4 (permalink) |
Personal
Sales Rating: (0)
[OP]
i thought a balance and blueprint meant you stuff the largest sized pistons and smallest rings possible into a stock cyl wall without boring, and have the crank balanced? correct me if im wrong.
mudhippy... thats a nice option..... but damn, way too expensive for me. |
#5 (permalink) | |
Personal
Sales Rating: (0)
Quote:
Engine Blueprinting: The basic concept of blueprinting is described as bringing the block into specification by re-machining the components of the block and sizing them to the original dimensions that the factory intended them to be. Engine balance: Engine balance is the design, construction and tuning of an engine to run smoothly. Engine balance reduces vibration and other stresses, and may improve the performance, efficiency, cost of ownership and reliability of the engine, as well as reducing the stress on other machinery and people near the engine. Involves carefully weighing and shaping nearly every moving part in the engine.
__________________
We're sorry, theYOTATECH member you have reached is temporarily out of order or is no longer in service. Please feel free to ask our many other highly informed members about your problem. Or try using the search feature to find the appropriate information by yourself, and solve the issue on your own. Thank you for choosingYOTATECH. Good bye. I'm Cuckoo For YOTA Trucks! Last edited by MudHippy; 06-30-2007 at 06:19 PM. |
#6 (permalink) |
Personal
Sales Rating: (0)
Is this for a 22re or a 3.0?
If you need some machine shop recommendations from personal experience let me know as we are in the same area. edit...what are the odds of 3 people on the same post in such close proximity?
__________________
1990 Xcab beast of burden 3.0 Rebuild/Precision balanced w/OS valves Custom ported/welded Intake manifolds Downey headers, Jacobs Ign 4" Trail Gear SAS + rear Kit R151 + Dual cases (2.28+4.7) 5.29's,Detroit/Lockright on 35 BFG's 140A GM CS144 alt/Hyd assist steering DOA Racing = $1200 lesson in who NOT to deal with Last edited by Ganoid; 06-30-2007 at 06:27 PM. |
#7 (permalink) |
Personal
Sales Rating: (0)
That's basically the way I've always heard and used it. You are bringing the clearances and tolerances into factory spec. For example the factory says connecting rod clearance is 0.025mm to 0.055mm and so you size your rod bearings to match that. The actual diameter you machine the rod and crank aren't as important as the measurement of the clearance that your Plastigage says. The difference is that when the machine shop blueprints your engine, they have the crank, rods and bearings and do the work to match them all together rather than you telling them to turn the crank and rods to some fixed diameter that matches the bearings you bought.
__________________
'91 Hilux XtraCab '01 Tacoma TRD '92 WilderNest Adventure Camper |
| Tags |
| 302, balance, balanced, balancing, ballance, blue, blueprint, blueprinted, blueprinting, blueprints, cost, engine, motor, print, shop |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| reman flywheel balance | ztrahp@bellsouth.net | 86-95 Trucks & 4Runners | 3 | 06-29-2007 08:49 PM |
| Balance of weight for jumping | bsebllhglyknit | The Fab Shop | 0 | 12-22-2006 02:00 PM |
| MTRs won't balance | SoiledGreen98 | Tires & Wheels | 17 | 10-25-2006 03:22 PM |
| Where to mount and balance? | MellamoPOUND | Tires & Wheels | 2 | 08-18-2004 10:02 AM |
| mod blueprint | BLKNBLU | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 04-13-2004 07:01 PM |
