Axle ratios
Axle ratios
Being new to the forum, I own 3 Toyotas, 2 1984's and a 1985. I would like to know what axle ratios were available back then. What type of identification did Toyota use to mark these axles?
Thanks in advance.
Thanks in advance.
They use colored paint on the ends of the pinion gear shafts. You have to remove the driveshaft to see it.
http://www.4crawler.com/4x4/4R_TechI...#Differentials
1984 Toyota Truck (except T100 & Tundra)
Carrier
Rear Axle, gasoline, 4x4 (4.10 ratio)
Front Axle, diesel (4.30 ratio)
Front Axle, gasoline (4.10 ratio)
Rear Axle, diesel, 4x4 (4.30 ratio)
Rear Axle, gasoline, 4x2, 1/2 ton, 3.15 ratio
Rear Axle, gasoline, 4x2, 3/4 ton, heavy duty (4.10 ratio)
Rear Axle, gasoline, 4x2, 3/4 ton, standard duty (3.73 ratio)
Rear Axle, diesel, 4x2, 3.58 ratio
Rear Axle, diesel, 4x2, 3.91 ratio
Rear Axle, gasoline, 4x2, 1/2 ton, 3.42 ratio
Rear Axle, gasoline, 4x2, 1/2 ton, 3.58 ratio
Rear Axle, gasoline, 4x2, 1/2 ton, 3.73 ratio
1985 Toyota Truck (except T100 & Tundra)
Carrier
Front Axle, diesel (4.10 ratio)
Front Axle, gasoline, 4.10 ratio
Front Axle, gasoline, 4.30 ratio
Rear Axle, diesel, 4x2, 3.73 ratio
Rear Axle, diesel, 4x4 (4.10 ratio)
Rear Axle, gasoline, 4x2, 1 ton, 3.90 ratio
Rear Axle, gasoline, 4x2, 1 ton, 4.10 ratio
Rear Axle, gasoline, 4x2, 1 ton, 4.30 ratio
Rear Axle, gasoline, 4x2, 1/2 ton, 3.07 ratio
Rear Axle, gasoline, 4x4, 4.10 ratio
Rear Axle, gasoline, 4x4, 4.30 ratio
Carrier
Carrier
I got it now, didn't know that the link was part of the answer. Appreciate the reply. Don't need an axle or components right now, but might pick up a complete truck locally for parts.
