axle question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-19-2009, 02:02 PM   #1 (permalink)
MurphyzRunner's Avatar
axle question
I have a 85 4runner with a 93 rear axle with a lockrite, This may be a dumb question but can I put my rear 93 axle third member up front and my front in the rear axle??? reason why is I want my lockrite up front and buy a spool for the rear.
__________________
4 inch allpro ft springs, rear disk, lockrite rear locker, 456 gears, 33' swampers, rock sliders...
MurphyzRunner is offline
Old 10-19-2009, 02:25 PM   #2 (permalink)
TOYOTA 1's Avatar
yes you can.
__________________
91 Toyota "built not bought"
Quote:
Originally Posted by BigBluePile View Post
I just bought a Toyota and I don't have any tools or any kind of area to work on it with and I'm wanting to drop in a V8 and clear 38's but I don't have any money and do I need to lift this if so what kind of lift and what do you recommend also I'm not sure if all terrains will work in mud is there another kind I have some rims that should work but they came off a yugo so is the bolt pattern the same...
TOYOTA 1 is online now
Old 10-19-2009, 03:01 PM   #3 (permalink)
AZkid's Avatar
they're both 8 inch diffs you silly head!
__________________
87 Runner "Chalkboard" SAS'in it babbbyyyyy!
If you have any parts to aid me in my SAS, PM me.
http://www.yotatech.com/f191/azkid-s...thread-189120/
Proud creator of the re-poster thread.
http://www.yotatech.com/f5/you-re-poster-193103/
AZkid is offline
Old 10-20-2009, 08:34 AM   #4 (permalink)
Quote:
Ya, I thought so.... anyways just checking someone told me that the newer axle out of the 93 truck was "heavy duty" because of the V-6 engine so that's why the dumb question.
__________________
Old 10-20-2009, 09:09 AM   #5 (permalink)
desertcamper67's Avatar
I've always assumed that you had to use another 4 cyl diff. Are their any internal parts that are different between V-6 and 4cyl? How about the fit? Is there any grinding needed to be done to the housing opening to make it fit?
__________________
'85 4Runner totaled and brought back 22RE-C 5spd 4.88's, Rear IFS axle with Detroit Locker and Tru Trac up front
Doug Thorley Header and LC Engineering Cam, K+N, Downey 3 inch leaves and Rubicon shackles with Pro Comp shocks
32x11.5-15 BFG AT's
Quote:
Do I like what I have-Yes.
Does it sound good-Yes.
Does it intimidate Ricers-Oh yeah.
Does it perform-Yes.
desertcamper67 is online now
Old 10-20-2009, 11:51 AM   #6 (permalink)
Etype R's Avatar
You can use a V6 diff on the front solid axle, it will bolt right up. The diff housings are different, as are the bearings for the V6 carrier. It is a stronger design, and some guys run them front and back.
__________________
1985 Toyota 4Runner - Full SR5 package - 4 inch lift - 35" tires
Etype R is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
