| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
auto to stick change
#2 (permalink) |
Staff
$400 is a steal. You can part it and make your money back in no time, even IF the trans is bad.
Btw, sounds like the accelerator pump is toast.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#3 (permalink) |
deathcougar is a genius
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. |
#4 (permalink) |
id go for it, especially for only 400 dollars.
the only big issue you will run into when switching it from an auto is drilling a hole in the end of the crankshaft to accommodate the pilot bearing. The only other modification you have to do is drill the firewall for the master cylinder, and prolly cut a little of the floor tunnel for the different shifter positions. I dont think you have to do any TCM/PCM mods on an efi engine that old.
__________________
04 taco, 3.4 5spd. loads of goodies, FZJ80 axle SAS in progress. 85 pickup, 327sbc, truggy, in progress. 86 mazda b2000 street queen haha. 92 mazda B2600i 4x4 absolutely mobs. 81 ford bronco drinks gas 90 mazda mx-5 all original. when in doubt, tach it out. |
#5 (permalink) | |
Staff
Quote:
All 22R crankshafts are drilled to accept a pilot bearing. If you are not sure, be careful the advice you give out. That can ruin a mans day.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| tacoma auto tranny dip stick | speddicord | Newbie Tech Section | 8 | 09-21-2007 04:25 AM |
| '03 Auto Taco, never change ATF ? | The Toe Cutter | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 05-17-2007 02:41 PM |
| Auto motor bolt up to stick? | iweb | 86-95 Trucks & 4Runners | 4 | 12-23-2005 02:36 PM |
| Auto Trans fluid change | Oakboy | Maintenance & Repair Archives | 1 | 12-20-2003 02:07 AM |
| Auto. tranny flush without filter change? | TDiddy | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 09-26-2002 11:37 AM |
