Alternator issue 84 pickup
Old 07-08-2016, 07:33 PM
pnworegon's Avatar
When I got my 84 with the 22r the guy selling it to me said it had the 3rd alternator in it within 6 months. It had a notable bearing noise but charged (unlike the first two), so he left it in and I wasn't worried about it either.... It died on me and with a new replacement still have issues. The battery is new and has been tested,all good, the voltage regulator is new as well.
I have gone trough and replaced battery cables and fixed some fraying wire on the alternators wiring harness as well, with all the good parts and wires I figured it was solved. After putting the battery back in yesterday from making sure it had a full charge, I noticed that when using the blinkers the voltage gauge bounces like the alternators bad. Should I got trough the hassle of pulling it out to have tested? Fairly sure it's not a parasitic draw, but I haven't done a meter test on the fuses yet to be sure, is there any other possible causes to the blinkers making my gauge jump? Any input would be appreciated, not looking forward to pulling the alternator out again.... Oh and the belts fairly tight so I don't think that would be it.
Old 07-08-2016, 08:57 PM
akwheeler's Avatar
Lots of vehicles have a noticeable twitch on the voltmeter when the turn signals turn on and off. If it's a low amperage alternator it will be more noticeable. Don't condemn your alternator because of this. If you really want to know if it's doing it's job turn on all of your accessories, wipers, headlights (hi beam), heater, A/C, stereo, and emergency flashers. Then put a multi meter on it, if you are still seeing over 12.8 volts or so with the engine running I wouldn't worry at all. you are more likely to see 13.5 to 14.5 volts though
Old 07-09-2016, 01:01 PM
osv
osv's Avatar
the alternator will put out a lot more juice at higher rpms... on some cars the blinker frequency will actually change as the engine is revved up.
like akwheeler said, put a meter on the battery posts, compare engine off vs. engine on, idle vs. revving, etc., everything else is just guesswork.
Old 07-09-2016, 06:33 PM
pnworegon's Avatar
My readings where 12.36 for loaded and non loaded, but when I went to the local parts house to double check the load test with a better set up it came back as my battery was fine, had 63cca more than needed. But the voltage wasn't reading, came back reading 12.36 as well for loaded vs non load. Looks like now I need to find a wiring diagram of the charging system and track down what's missing or frayed/grounded
Old 07-09-2016, 06:47 PM
osv
osv's Avatar
http://www.aa1car.com/library/charging_checks.htm
Old 07-11-2016, 11:02 AM
bccooper's Avatar
If it ends up being your alternator again, which I doubt it is you could always put a GM one wire on it and call it done.
Old 07-11-2016, 08:26 PM
pnworegon's Avatar
I found the issue, their are some missing wires in the harness from some one hacking the vacuum lines out and combining wires off the master fuse box. Noticed two wire was cut off a connected really close when I was doing a voltage drop test. Everything is working properly just not getting flow back to the battery. So I'll have to do a little wirire changes. Thanks for the input everyone, much appreciated, and helped a lot.
Old 07-12-2016, 12:13 AM
Staff
Terrys87's Avatar
84s have an External Voltage Regulator, not sure how to test it but it is a little black box mounted on the Inner Fender if I recall correctly. Just want to make you aware of it.
Old 07-12-2016, 04:51 AM
pnworegon's Avatar
Yeah mounted above the alternator on the driver fender well, that was replaced and should be fine
Dismalbogs
02-26-2016 01:30 PM
your-real-dad
Engine Swaps
02-24-2016 10:44 AM
mcognv
02-22-2016 09:36 PM
rust bucket
01-31-2016 07:48 PM
data
03-21-2005 04:07 PM
Quick Reply: Alternator issue 84 pickup
