AC Belt Needed??
AC Belt Needed??
'85 22RE
I just replaced my timing chain, and as I'm putting belts back on, I had this thought that maybe I don't need to put the AC belt back on. My AC doesn't work and it actually sounds like a bearing on the AC pulley is going out. So my questions is: Do I have to put the AC belt back on? Does the AC belt help move other parts, will not putting it on mess on timing or anything? Will not installing my AC belt improve gas mileage?
If the belt only goes from the crank pulley to the a/c compressor, you do not have to put it back on. I doubt you will see any difference in fuel mileage though.
Staff
You can leave the belt off. I have seen two styles of pulley but the bearing can be swapped out https://www.yotatech.com/forums/f199...l#post51649322 when you get to that point.
TURBOrunnerNM
07-22-2015 11:01 AM
Jnkml
07-06-2015 01:20 PM
FS[NorAtl]: 1989 pickup beds and leer cap Rhode island
mickyd9990
07-06-2015 09:01 AM
