86 4runner stalling/backfiring - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-31-2009, 01:35 PM   #1 (permalink)
Unhappy 86 4runner stalling/backfiring
This spring while driving my 4runner between where I live and town, about 45 miles, about 65 miles per hour the truck would started jerk/pop/hesitate. So all I needed to do was just back off the throttle just a bit and it drove fine. As the summer went on the problem started to get worse and happen closer from home. At its worse it would not even idle well or die at an idle and when I rev'ed the motor when not in gear it would pop and backfire. I replaced the cap and rotor and got no change. I also checked the muffler because it sounded like it was plugging up, but removing it made no change. So it sat all summer long. So now I am looking at it again cause of hunting season. After a jump start I drove it around. I got to the main road ok, no problem. Then after hitting about 40-50 miles per hour it started the hesitating/sounding like a backfire again. So I limped it back home, no matter what gear, speed or RPM, the problem did not go away. Got it back in the yard and it started to seem ok again. Went on a test drive again and got the same thing. Only thing different this time around as to last spring is it seems to run fine at an idle and so long as it is not in gear I can rev it up and no problem. So something has changed and I have no idea where to even start to look for a problem. I don't understand why I can start up and have it run fine and rev it up to 4K, but get out on the road have start to have problems.
slayera is offline
Old 10-31-2009, 01:49 PM   #2 (permalink)
TOYOTA 1's Avatar
is the check engine light on?
i would also check the fuel pump/filter.
__________________
91 Toyota "built not bought"
Quote:
Originally Posted by BigBluePile View Post
I just bought a Toyota and I don't have any tools or any kind of area to work on it with and I'm wanting to drop in a V8 and clear 38's but I don't have any money and do I need to lift this if so what kind of lift and what do you recommend also I'm not sure if all terrains will work in mud is there another kind I have some rims that should work but they came off a yugo so is the bolt pattern the same...
TOYOTA 1 is offline
Old 10-31-2009, 01:58 PM   #3 (permalink)
No check engine, except when it dies from poor idle. Will have a go at a fuel problem, but I think the filter was change out. The 4runner was given to me.
slayera is offline
Old 10-31-2009, 02:04 PM   #4 (permalink)
22RUCRAZY's Avatar
I had a similar problem my choke was sticking closed at random times , is it 22r or re , if you have carb spray all linkages with carb cleaner . GOOD LUCK
22RUCRAZY is offline
Old 11-05-2009, 09:38 PM   #5 (permalink)
I would check the fuel filter, when they sit for a while the filters catch any crap in the tank. If it is Carb'd the filters are cheap and can be changed in minutes.
__________________
1985 Pickup-4x4-22R-Bone Stock
AbeWhat is offline
Old 11-06-2009, 09:48 AM   #6 (permalink)
It is fuel injected. I have the filter now. Just need some time to put it on. Right in the middle of deer hunting. Picked up a manual too. Fuel injected is the re type, correct?
slayera is offline
Old 11-06-2009, 10:02 AM   #7 (permalink)
TOYOTA 1's Avatar
yes...
__________________
TOYOTA 1 is offline
Old 11-09-2009, 06:34 PM   #8 (permalink)
OK, replaced the fuel filter. Seems to run better at top speed, has more power and idles better, but still have the same problem. The filter looked like the original toy filter, at least it had a toy label on it and the bolts were rusty. Either way it was probably time replace it. It is still popping and hesitating, but higher speeds. Also still seems to have more trouble up hill than down. Fuel pump next? BTW, the 4runner has 167,000 miles on it. I am going to try to set the timing and and check the plugs too.
Also, this many mean nothing but seems like the colder it gets the the better it will run. It did sit over the summer at the warmest, but that was when it was having the most problems and ran the most. Till this fall and today after the replacing the filter was even cooler. Could there be some relation?
Loved the Chilton manual, not. It gave illustrations of the filter only and did not say where it was even located. Good thing I cruised this board or I would have never found it. Love the pics with the guy holding a big ol torque wrench like the truck was not in the way or anything. Read another thread about the starter being a great place for the bolts and he was right. Ended up dropping the bottom one taking it out and the top one reinstalling it. Good thing I was able to get my fingers in there.
Anyway, I don't know about other toy trucks, but if I had known before hand I would have relocated the filter with a generic filter on the inside fender wall. There was more than enough room, just would have needed a little extra gas line, steel tubing, and some clamps. I live 45 miles out of town, so it was just faster this time around to reinstall the replacement. I would recommend one of those with a removable glass bowl. It would be a real pain if you are out in the sticks and needed to check it or clean it.
slayera is offline
Tags
4runenr, 4runner, 86, backfires, backfiring, fine, gear, idleing, idling, problem, revs, stalling, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
