85 xcab rear springs sagging - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-17-2006, 09:10 AM   #1 (permalink)
Wondered what "without lift" options there are for my new to me 85 Xcab. Driver's rear is sagging significantly. Front springs are fine, truck def has an "ass down" attitude. I'm restoring this for my daughter's first car, so want everything stock. Is it possible to get aftermarket springs without lift? Anyone have some good stockers near Tx?
Texx is offline
Old 10-17-2006, 09:21 AM   #2 (permalink)
bktaco's Avatar
i think NWOR sells replacement stock springs. i dont know if they are stronger upgrades, true oem replacements will probably end up sagging after a few years tho. i have never dealt with NWOR , but i have heard that they can be hard to deal with.
__________________
Yotas I've known...
83 pickup
87 Extracab SR5 4WD pickup
92 4WD pickup
85 long-bed pickup
90 pickup
Yotas I own...
00 Extracab SR5 TRD Tacoma (3RZ) **FOR SALE**
85 SR5 4Runner
Check the LongBeachRacers, pounding Tacos in the desert!
bktaco is offline
Old 10-18-2006, 07:11 AM   #3 (permalink)
MtnToys's Avatar
Get some old man emu (OME) springs made by ARB. They are bolt on, the ride is excellent and they flex better then stock. They have 2 inches of lift but if you get the soft ones I bet they would look stock. I have a set of these on an fj60 and the ride is far superior to stock.
http://www.off-road.com/toyota/reviews/ome/index.htm
MtnToys is offline
Old 10-18-2006, 07:32 AM   #4 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
OME, NWOR or ALCAN...
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 10-18-2006, 09:17 AM   #5 (permalink)
bktaco's Avatar
mtn toys: do the OME springs end up sagging too, or are they beefy enought to hold up longer? i am looking at those springs for my 4runner in the next year or two...
__________________
Yotas I've known...
83 pickup
92 4WD pickup
85 long-bed pickup
90 pickup
Yotas I own...
85 SR5 4Runner
bktaco is offline
Old 10-18-2006, 09:30 AM   #6 (permalink)
phorunninduke's Avatar
Send a message via AIM to phorunninduke
I have an extra set of rear springs. IIRC the truck they came off of still had the right ride height. They where an extra set for the "rears up front lift" that I never used.
They need to be cleaned up but you can have them for S+H (heavy)
phorunninduke is offline
Old 10-19-2006, 05:55 AM   #7 (permalink)
I sure appreciate the offer! I'm gonna check around locally, may take you up on that. I need to measure my front height and see if it's lifted. It's on 235's right now, and there's looootttsss of open area...may have a small lift on it already.
Texx is offline
Old 10-19-2006, 08:36 AM   #8 (permalink)
4Crawler's Avatar
Add-a-leaf (like the Rancho Soft-Ride AAL kit) or JC Whitney also sells a stock height rear spring:
http://www.4x4wire.com/forums/showfl...t=1#Post931633
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-21-2006, 05:24 PM   #9 (permalink)
Personally, at over 20 years old, I'd replace them. Stay away from NWOR at all costs. The only place I know that sells stock-height springs is JC Whitney. Otherwise I echo the idea of 2" OME springs. Some of the nicest on the planet.
rockota is offline
Old 10-24-2006, 05:58 PM   #10 (permalink)
MtnToys's Avatar
Quote:
I have only had the OME for a year or so. No signs of them sagging. We loaded the truck with 15 sheets of 3/8 plywood and the rear wasnt sagging. Keep in mind this is on an FJ60 but im sure they are similar to the 4runner and pickup springs. I would have installed these springs on my runner in a heart beat if i wasnt looking for a larger lift to fit 35s. I have only ever herd excellent things from others who have used OME.
MtnToys is offline
Old 10-27-2006, 07:19 AM   #11 (permalink)
If you are wanting some flex I would go with the All-Pro superflex rear springs. They have a 3" lift to them for only $289 and you are off to having a great lift with more flex than you will ever need. Something to consider.
__________________
84 x-tra cab All-Pro Superflex springs, All-Pro Hy-steer, All-Pro Johnny joints in the rear, All-Pro shock hoops with Bilstien 5100 up front, Bilstien 5100 rear, All-Pro flip kit front and rear, All-Pro 2.5" shakels front and rear. Built 86 22r.
84TonkaYoda is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
My rear is sagging. '85 4runner michalik_piotr 84-85 Trucks & 4Runners 20 04-10-2007 09:58 PM
85 Xcab exhaust...what fits!!???? Yoda 84-85 Trucks & 4Runners 1 12-04-2006 07:02 AM
Sagging rear Downey Rear Leaf Springs Bear80 95.5-2004 Tacomas & 96-2002 4Runners 4 06-21-2005 11:06 PM
02 Runner sagging springs Hawaiian4R 95.5-2004 Tacomas & 96-2002 4Runners 0 08-22-2004 05:29 PM
85 toy xcab 4x4 gunnbunny 95.5-2004 Tacomas & 96-2002 4Runners 0 02-20-2003 06:11 PM
2009 InternetBrands, Inc.
