Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
85 Turbo Gas SR5 PU 2X2
Does anyone know why most places ( forums, parts houses, etc. ) do not list the 85 model year as having a gas turbo model?
On the same subject: someone from this forum who has a gas turbo Toy PU told me that the radiator has a connection that goes to the turbo. This truck has been in the family since new and the radiator was rebuilt once and i took the radiator out and reinstalled it. There wasn't any hose from the radiator to the turbo. So if the 85 is the only model without such a connection how difficult would it be to put one in and would it be worth the effort? |
| Sponsored Links |
#2 (permalink) | |
Quote:
__________________
'85 4runner, finally lifted.
Done milling my steering arms! http://www.pirate4x4.com/forum/showthread.php?t=548270 Working on DUAL-TRANNYS |
#3 (permalink) |
it was, it just wasnt very common. not too many of em around
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22RE 258,000 miles on original motor pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#4 (permalink) |
yes , there is a cooling line from the rad to the turbo ..
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 MY PAGE 2WD fourm I frequent NEW Trekker forum |
#6 (permalink) |
Can you elabor8 some or point me to a picture?
Isn't it possible that the 85 didn't have it? i know that Volvo didn't add an inter cooler until a year or two after it was introduced. The user manual on my truck talks about letting the PU idle a minute or so before turning it off. |
#7 (permalink) |
I can get you a pic of the rad only .. it is the front side , on the otherside , top tank , there is a tube (you can see the tube zap straped on the mount flange) it is threaded to fit into the top , front of the tank ..
this rad is going into my toyota Trekker with a 3.4L .. so I can't supply you with a pic of it in an /85 vintage . ![]()
__________________
#8 (permalink) |
Even if I could find a radiator from a later model how would I connect it if the earlier turbo doesn't have a place to connect it to? and my guess would be the channeling for the coolant would be missing as well?
23 years and still running...maybe I should leave well enough alone. Thanks for the picture...good luck with your Trekker! |
#9 (permalink) |
just block it off ..
I'm not going to be running a turbo , but a supercharger in mine .. so I wont be needing the "port" for the cooling .. I will be using a "block" plug , and sealing the hole ..
__________________
#10 (permalink) | |
Quote:
There is no doubt that there is scale inside the core but it never overheats and there is no coolant in the oil. The last time i had a problem with the radiator i had it rebuilt; that was 13 years ago and for about four of those years the truck sat with the radiator drained. No i have a choice of three radiators none of which have that extra turbo connection: 1 is a wide one core aluminum radiator 2 is a large one core brass radiator and 3 is a 3 core radiator which is obviously the same thickness as the others so i'm guessing that each core is thinner. Either that or i don't understand the engineering of it all. So the question is which one is best? |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1986 sr5 turbo | ntgamache | 86-95 Trucks & 4Runners | 1 | 08-27-2008 03:22 AM |
| 86 sr5 turbo help! | trboyota | 86-95 Trucks & 4Runners | 10 | 07-19-2007 08:32 AM |
| 2x2 Parts Truck | atistang | 86-95 Trucks & 4Runners | 7 | 12-04-2006 07:27 PM |
| All NEW Segway 2x2! | joshik | Off Topic Talk | 1 | 03-12-2003 10:32 AM |
| Do 3.0L TD headers and turbo fit 3.0L gas engines? | DH6twinotter | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 01-13-2003 04:07 AM |
