85 stock suspension questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-22-2007, 09:44 AM   #1 (permalink)
My 4 runner is almost scary to drive on the street. It tracks grooves in the road, and swerves to the right when i hit the brakes.
There is a dogbone that connects the front axle to the chassis. The bushings are bad, but no one seems to know what the part is called, or where to get replacement bushings...
Suggestions on replacing it?
2. Is there a stronger, or quality replacement part for the draglink (i think thats what its called..it connects the steering box to the knuckle)... Truck is fairly stock with 32" tires.... I purchased a rebuild kit from napa for nearly 60 bucks, but i'm wondering if there is a better/stronger replacement seeing as i beat the crap out of my poor truck, and that is an important piece....
any suggestions/links will be greatly appriciated.
85ghettorunner is offline
Old 08-22-2007, 10:16 AM   #2 (permalink)
ocdropzone's Avatar
My guess is that you have got more than one issue affecting your handling. on a 22 year old truck if you have got one bad bushing you have got more. Have you checked your brakes, tie rod ends & wheel bearings too?
My '81 was wandering too (no front Track bar) my issues were a combination of the drag link and a steering joint...
__________________
~Robb
'81 Trekker The B4Runner Build
TREKKER Forum
Mini FAQ/Misc Ideas Thread
**TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES
LINK TO ONLINE FACTORY SERVICE MANUALS
Drive a real 1st Gen
Wheel Responsibly, Don't Screw It Up for Others
ocdropzone is offline
Old 08-22-2007, 11:50 AM   #3 (permalink)
4Crawler's Avatar
The "dog bone" is called the torque rod. Not sure there are aftermarket bushings for it, likely need to replace it with a used one or get an adjustable rod. It controls bump and brake steer. Tighten up and/or replace the rod ends in the drag link. Stock unit is fine, rebuild it and it should be fine.
Also, check the knuckle and wheel bearings:
- http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-22-2007, 04:40 PM   #4 (permalink)
who makes an aftermarket (or stock) torque rod?
Old 08-22-2007, 04:51 PM   #5 (permalink)
4Crawler's Avatar
Quote:
I think SuperLift and maybe Rancho make adjustable torque rods and draglinks. Or you can modify yours with heim joints:
- http://www.mindspring.com/~jayk3/toyota/torque.htm
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
85 toyota pickup suspension lift question corvettelvr73 84-85 Trucks & 4Runners 8 05-09-2007 10:20 PM
85 4runner bolt on suspension steelynorm 84-85 Trucks & 4Runners 6 03-30-2007 09:31 PM
Off-roading with a stock suspension. BYAHnate 95.5-2004 Tacomas & 96-2002 4Runners 21 03-12-2007 06:58 PM
stock 85 runner suspension Bdog 84-85 Trucks & 4Runners 14 12-05-2006 09:40 PM
85 Toy: Best Bang for the Buck Suspension?? Stump1883 Offroad Tech 13 02-06-2004 09:49 AM
2009 InternetBrands, Inc.
