| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) | |
Have you checked all your fuses? Inluding the big silver EFI fuse. Then check the wiring to the injectors. Also check resistance on those wires if everything else checks good. That's about as good a starting place I can give you.
__________________
Quote:
#3 (permalink) |
well every fuse i could find i pulled and checked. all were good. but where is the big silver efi fuse? please if there is anyone out there that knows anything about toyotas please give leave some advise on where to go next
#4 (permalink) | ||
Ok, so I did a little research for you. Did you check the injector harness with a multimeter?
Quote:
__________________
Quote:
#5 (permalink) |
If your truck has a solenoid resistor check and see if its good, the solenoid resistor on my 86 4Runner went bad and the injectors wouldn`t operate, i had a spare one laying around and put it on and my 4Runner started on the first try.
__________________
86 Toyota 4Runner Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper. |
#6 (permalink) |
Yup, check your resistor. That's more than likely the cause. Bout the only way to check is to try another one, lol.
__________________
85 4Runner DLX. Autotragic with some tires |
#7 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
Also check in the harness on top of the intake manifold. There are splices in the injector wiring there and it is known for those splices to fail.
__________________
Quote:
Insomnia: it's a way of life.
| Tags |
| 1985, 22r, 4runner, 85, crank, resistor, solenoid, terminal, wont |
