YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-17-2008, 08:39 PM   #101 (permalink)
Hayes's Avatar
Send a message via AIM to Hayes
I like the cooler design.
__________________
-Hayes
Hayes is offline
Sponsored Links
To remove this ad, register today!
Old 03-17-2008, 08:52 PM   #102 (permalink)
DIRTCO's Avatar
Also mounted up the 6"x9"s, once these get tore up from the elements I will try some marine speakers
And some overall pictures of everything together
__________________
The new project and daily driver
86 Turbo 4Runner
http://www.yotatech.com/f116/86-turb...-build-155840/
The old Trail Rig - RIP
85 4Runner, Bobbed, Dovetailed, 37's, Dual cases, the list goes on.
http://www.yotatech.com/f115/85-4run...thread-134399/
DIRTCO is online now
Old 03-17-2008, 08:56 PM   #103 (permalink)
DIRTCO's Avatar
Quote:
Thanks, I still need to mount the latch for the cooler lid.
__________________
86 Turbo 4Runner
Old 03-17-2008, 09:02 PM   #104 (permalink)
Volcom's Avatar
Quote:
Originally Posted by DIRTCO View Post
That's a bada$$ stance for a 4Runner
__________________
1984 Toyota 4Runner
EFI swap
TG 4" springs
Marlin Crawler Dual Ultimate Crawler
39.5" Iroks
My 4 wheel drive club
http://www.rockfrogs.org
Volcom is offline
Old 03-18-2008, 06:56 PM   #105 (permalink)
DIRTCO's Avatar
Quote:
Thanks, dovetailing and lowering the rear made a huge differance. Now I need to get some new tires, that will make a huge differance in how it wheels and looks.
__________________
86 Turbo 4Runner
Old 03-18-2008, 08:19 PM   #106 (permalink)
Hayes's Avatar
how much tread is on your old tires?
__________________
-Hayes
Hayes is offline
Old 03-18-2008, 09:59 PM   #107 (permalink)
pigpenfab's Avatar
i have one of the first sets of 30 spline longfields in my rock buggie.WAY stronger than the 27 spline. when i put on 37" mtrs the 27 spline axles broke. i called bobby long and bought a set of 30 spline and traded my 37" MTRS for 40"s. Since this upgrade ive broken 2 t cases, ring and pinion, arb, and a detroit not to mention lots of drive shafts. i love the 30 splines. only problem i noticed is if you bend your axle housing at all they are almost impossible to get out. i live in Arizona, i run toyota axles, 40" mtrs on full tube suzuki based buggy, 5.12 ring and pininons, 6.4:1 transfer case, spool front and rear, with hydro steer. My moto is if in doubt gas it!! and the longfields are still alive and strong.
pigpenfab is offline
Old 03-20-2008, 04:27 PM   #108 (permalink)
DIRTCO's Avatar
Not much, I'm guessing around 5/32". They are pretty close to bald, here is a picture.
__________________
86 Turbo 4Runner
Old 03-20-2008, 04:29 PM   #109 (permalink)
DIRTCO's Avatar
Quote:
That's good to know, well worth the $$$.
__________________
86 Turbo 4Runner
Old 03-24-2008, 06:11 PM   #110 (permalink)
DIRTCO's Avatar
I worked on the 4Runner a little bit this weekend, it's getting a lot closer to being out on the trail. I figure a few more weekends and it will be set.
Here's how it looked when I pulled it in shop.
__________________
86 Turbo 4Runner
Old 03-24-2008, 06:34 PM   #111 (permalink)
DIRTCO's Avatar
After I pulled it in the shop, I figured that it was a good time to flex it out. I wanted to check clearance and shock travel and make sure there was not any problems.
Everything looked good. I lifted the driver's front tire 35" before a tire came off the ground (with 28 PSI in the tires).
__________________
86 Turbo 4Runner
Old 03-24-2008, 06:48 PM   #112 (permalink)
DIRTCO's Avatar
The driver's front leafspring is just past negative arch and has 1 1/2" left on the shock up travel. You can also see how close the tierod end is to the leafspring.
I still need to get some bumpstops for the front and rear, I just want to get the suspension figured out first
Here is the other side. The shock still has room for some more down travel but the shackle is pretty much streched out. I'm sure that on a trail it will droop some more. The brake lines still have plenty of room to work with and everything else seems to look good.
__________________
86 Turbo 4Runner
Old 03-24-2008, 07:02 PM   #113 (permalink)
DIRTCO's Avatar
Here is one picture of the front to show the firewall clearance, I'm sure that when turned and on the trail it will rub; so I will have to tub the firewall (It used to with the old springs so I had already planned on it )
I'm also thinking about pulling a leaf out of the front. These springs used to be under a 94 4Runner with a 3.0 V6 and a winch. That truck sat super low, but mine is a little taller. They also seem to be stiffer than the rear springs (and my old front springs). These things are used and abused, so they are not going to settle any more (without changing them)
__________________
86 Turbo 4Runner
Old 03-24-2008, 08:40 PM   #114 (permalink)
DIRTCO's Avatar
And the rear ...
The shocks have more than enough travel in both directions. The spring is pretty much flat at uptravel and the other spring can travel down a little more before the shackle is maxed out.
I might have to trim the rear fenderwells some more
__________________
86 Turbo 4Runner
Old 03-24-2008, 08:52 PM   #115 (permalink)
DIRTCO's Avatar
After all that fun, it was time to get back to work. I started by making the Co2 Tank protection bar / cage thing
Then I braced it up ...
And added some paint.
__________________
86 Turbo 4Runner
Old 03-24-2008, 09:00 PM   #116 (permalink)
DIRTCO's Avatar
Then it was time to brace up the entire rear tube work some more. I bent up a couple bars and cut some holes in the rear fenderwells. It should help to brace it up quite a bit.
__________________
86 Turbo 4Runner
Old 03-24-2008, 09:08 PM   #117 (permalink)
DIRTCO's Avatar
I then mounted the Hi-Lift jack and attached some hold downs for the cooler lid (no pictures). Here are a couple pictures of how it all came out.
__________________
86 Turbo 4Runner
Old 03-24-2008, 10:45 PM   #118 (permalink)
sloppy85toy's Avatar
that is awsome this project got me very interested in bobbing mine just the fiberglass work will be hard.
__________________
(sloppy85toy) 85 sr5 4runner 22re 5.29 spooled rear sittin on three inch lift and 33 inch boggers
sloppy85toy is offline
Old 03-25-2008, 08:47 PM   #119 (permalink)
DIRTCO's Avatar
