85 4runner Front Axle Seal Questions - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 07-16-2012, 01:39 PM   #1
On my 85 4runner, there seems to be oil/grease on the knuckles of my front axle. On the back (side closest to diff) there is a metal ring holding on a seal to the knuckle, bolted to the whole hub assembly. These are around 10, 10mm bolts and all are pretty loose and not tightened down, should they be tightened down to a torque spec or are they suppsoed to remain loose to make movement easier?
Thanks
sp543 is offline   Reply With Quote
Old 07-16-2012, 01:47 PM   #2
waskillywabbit's Avatar
Tighten them down and they'll shear. Snug is about all they will take.
Knuckle service kit will let you rebuild the knuckles.
:wabbit2:
waskillywabbit is offline   Reply With Quote
Old 07-16-2012, 02:30 PM   #3
Im guessing it the inner axle seals, correct? Previous owner said he rebuilt it not to long ago, so i rather just do the seals instead of the whole thing.
Using this method, i can do this right?: http://www.youtube.com/watch?v=o3Y5bQGiezY
What parts, gaskets, seals etc. will i need in addition to the inner axle seals?
Old 07-17-2012, 09:58 AM   #4
I should probably replace the felts and rubber seals on the knucle as well along with the rock ring, so this kit should work well correct?: http://www.jtoutfitters.com/knuckle-...soqgjgnkl500c6
And using the method in the video, do i have to pack the housing with grease or add any fluids or anything besides changing out the diff fluid when im done?
Thanks
Old 07-17-2012, 10:06 AM   #5
Why are you rebuilding it if just rebuilt?
:wabbit2:
Old 07-17-2012, 10:08 AM   #6
There is diff fluid leaking onto the knuckle ball, so im guessing the inner axle seal was not replaced or started leaking. Im going to use heavier duty seals so it should work better, everything else is perfect besides that.
Out of these 2 kits, are there any major differences in quality or materials, or are basically the same?
http://www.napaonline.com/Catalog/Ca...428_0288207990
Void Dwellers 1995 4Runner 4WD SR5 voiddweller 86-95 Trucks & 4Runners (Build-Up Section) 19 05-02-2016 10:10 PM
85 Xtra Cab 4x4 - Retired & Restored trail rig 6th Gear 84-85 Trucks & 4Runners (Build-Up Section) 15 07-14-2015 08:01 AM
Go Cruisers!! Yoda Early Land Cruisers 3 07-07-2002 09:10 AM
Calling all cars.. calling all cars.. MRael Off Topic Talk 12 05-29-2002 03:23 PM
Tags
2nd, 4runner, 85, axle, ball, front, gen, housing, knuckle, leak, rebuild, replace, seal, service, solid, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
