'85 2wd Pickup, coolant leak - head gasket? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-25-2009, 01:41 PM   #1 (permalink)
Last December the truck started blowing white smoke while idling, but pretty much went away while driving it. I thought initially it was flooding, running rough, and the bolts that hold the top air horn on the carb were loose. So I tightened them up (at least a full turn each) and it ran better. After that I decided to do a Weber 32/36 and Offenhauser intake swap. I just finished up the swap this past weekend and went to change the oil before I started it and at least a 1/2 quart of coolant came out first. I filled it with oil and started it, and the temperature rose really quickly, about 3-5 minutes after starting it, it was way past the normal operating temp. Thinking the problem is a head gasket I just ran a compression check and got the following readings: #1: 168 psi #2: 138 psi #3: 143 psi #4: 169 psi The threads on the #2 and #3 spark plugs were wet. Although these readings indicate something is wrong with #2 and #3 I would have expected much lower readings for a blown head gasket. But, I guess if one of the water jackets between #2 and #3 blew out on both sides that would explain this. The timing chain and guides were replaced about 20K miles ago, so I don't think that is the coolant leak. I just wanted some confirmation that the head gasket is the problem before I go take it apart. Thanks for any help.
__________________
Robby Whitesell
1985 Toyota Pickup, 2WD, 22R 2BBL
Robby1870 is offline
Old 11-07-2009, 01:07 PM   #2 (permalink)
toyotabull's Avatar
If you have a lower comp in the center 2 cylinders and water on the plugs, then you have a leaking head gasket or a head problem. I would take the head to the shop and have it checked and put in a new head gasket.
__________________
85 toyota rancho lift
33 in tires on 15X8 steel
270 lift cam and flat tops
Those who do not learn from history are doomed to repeat it, or they're showing up their friends. Again!
toyotabull is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
