85 22re running rough
So I've searched quite a bit and nothing seems to help. So hears the back story, I have an 85 Extra Cab with a 22re. A few months back the fuel pump went out and I decided to run an inline pump. Well that pump died Friday. So I warrantied it and replaced it. Got about 20 miles into my commute home and the truck started running super rough. Limped it the last 30 miles home and decided to replace the new inline pump with a factory replacement pump. Got the new pump in and the fuel lines repaired where the inline pump was. Truck fired right up but still ran rough. Thinking it was a spark issue I stared pulling the plug wires off the distributor can while it was running. Turned out when I pulled #3 away a little the truck revved up and ran fine. So I pulled that plug and cleaned it. Put it back in and the truck ran good. So I decided to replace all the plugs. Once replaced the truck ran like crap again. So I replaced the wires as well as the cap and rotor. Truck still runs super rough and I'm at a loss now. Sorry for the essay but I figured it would help. Here's a couple pics of the rig.
