85 22re codes - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-04-2006, 01:43 PM   #1 (permalink)
85 22re codes
pulled two codes... 6 and 10. the only symptoms i seem to have (that i know of) are smelly exhaust (burning oil? doesn't really smoke or anything?) and it's slow to start most of the time. not that it turns over slow, it turns over fine. it just takes a while for it to spark up and run. oh, and it usually starts better/faster when the engine is warm. usually. best place to start?
just for easy reference...
__________________
1985 4runner EFI
Concord, NC
chuckwhut is offline
Old 03-06-2006, 05:26 PM   #2 (permalink)
really? no one?
__________________
1985 4runner EFI
Concord, NC
Old 03-16-2006, 09:36 AM   #3 (permalink)
someone mentioned that my cold start injector might be bad, or the ignition isn't sending a signal to it or something. how do i go about checking this?
__________________
1985 4runner EFI
Concord, NC
Old 04-16-2006, 08:38 AM   #4 (permalink)
well its still starting like crap, only more consistantly. every time i get in i get embarrased if people are around. lots of times people ask if i need help, and i say, nope, it'll crank in a minute. so yesterday i changed plugs, wires, cap and rotor, with no result. any help?
__________________
1985 4runner EFI
Concord, NC
Old 04-16-2006, 08:43 AM   #5 (permalink)
4Crawler's Avatar
Try the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 04-16-2006, 12:30 PM   #6 (permalink)
prob not cold start timer if it starts well when its warm.
buy a Weber
Superflex84 is offline
Old 04-18-2006, 12:47 PM   #7 (permalink)
interesting afternoon...went to the stealership to check on the price of 4 new injectors...mainly out of curiosity. when i did the tune up the other day, i thought the plugs looked white, like it was running lean. so my theory was...slow to start, plugs show lean, bad smelling exhaust, and the occasional sputtering loss of power....maybe my injectors were going/gone bad. i showed my old plugs to the mechanincs at the shop there and they said they looked fine. so maybe it's not lean. but i told them i wanted to take the injectors off and test them and they told me there was no possible way to do that, even though i'm sitting here looking at the FSM outlining how to do it. so i don't know.
oh yeah, i went to crank it, and it didn't, as usual, so i turned off the key and turned it back on...nothing. i mean not a slow try, not one noise. great. i sat there for a while checking fuses, checking grounds from the battery to the starter, etc. everything looked fine. but key makey no noisey. no starty. so i ask the stealers for a jump, and he hooks the jump pack up (he actually hooked it up backwards the first time!! wtf???) and it cranked right up.
so after all this, is my slow to start problem being caused by a weak battery, and the other symptoms are non related? i would feel like an ass. guess i need to bust out the old test light and see if i can find some random wire drawing power when it shouldn't be.
my clock is never right when i turn my truck on. it is always some random number. not 12 everytime, it doesnt pick up where it left off, its just random. stupid clock.
__________________
1985 4runner EFI
Concord, NC
Old 04-18-2006, 05:44 PM   #8 (permalink)
Quote:
Originally Posted by 4Crawler
thanks...but that didn't do anything...i ohmed out the ignitor, primary read at 0.9 (as opposed to the 0.5-0.7 it should be) ohms, couldn't get a reading other than infinity for secondary reading, maybe wasn't making contact with the terminal...
__________________
1985 4runner EFI
Concord, NC
Old 04-18-2006, 05:49 PM   #9 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
definatly sounds like a battery....explains the slow crank and battery.....but before you $$ up for a bat check your connections....make sure there is no corrosion or bad wires...
if you have a bad connection somewhere it could cause all the probs your seeing...
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 04-18-2006, 06:53 PM   #10 (permalink)
Quote:
aside from the exhaust smell, stuttering acceleration, not so hot gas mileage, and i doubt the 2 codes, seems they would clear out if the battery died or was intermittantly disonnected
__________________
1985 4runner EFI
Concord, NC
Old 04-18-2006, 07:06 PM   #11 (permalink)
AH64ID's Avatar
but could return due to a lack of volts??? check the connections, if that dont work new bat, clear the codes and see if they return...electrical ghosts SUCK
__________________
-John
AH64ID is offline
Old 04-18-2006, 07:27 PM   #12 (permalink)
i agree, i have a few more ghosts i would like to exercise as well...
__________________
1985 4runner EFI
Concord, NC
Old 04-19-2006, 03:16 AM   #13 (permalink)
check the ground to the body, ground on the intake plenum, the ones on the plenum loosen up from vibration sometimes, see it at the dealer a lot
__________________
Fabricator/Eater of Pizza
Old 04-19-2006, 12:56 PM   #14 (permalink)
checked all my grounds and replaced battery terminal connectors today, same prob. i still have a feeling it's fuel issue, and i noticed some gasoline on some engine parts today, i am trying to find that leak hoping it will solve my slow starting/running lean.
__________________
1985 4runner EFI
Concord, NC
Old 04-19-2006, 02:08 PM   #15 (permalink)
AH64ID's Avatar
if the clock is loosing its memory you have a elec issue...you might have 2 issues.....
__________________
-John
AH64ID is offline
Old 04-19-2006, 02:12 PM   #16 (permalink)
that's what i'm thinking
__________________
1985 4runner EFI
Concord, NC
Old 04-21-2006, 09:02 PM   #17 (permalink)
found my fuel leak, the "pulsation dampner". how likely is it that my slow starting and running lean is from this leak?
__________________
1985 4runner EFI
Concord, NC
Old 04-22-2006, 04:39 PM   #18 (permalink)
Quote:
It IS your problem to excessive cranking. The fuel pressure is bleeding down when it the pulsation damper leaks. Don't forget to purchase new brass washers when you replace it.
84sr5yoty is offline
Old 04-27-2006, 10:26 PM   #19 (permalink)
vsv and damper replaced. relatively no change. i'm sad. exhaust still stinks, and actually seems to be smoking a little, or more than a little now. crap.
__________________
1985 4runner EFI
Concord, NC
Old 04-28-2006, 04:30 PM   #20 (permalink)
What color smoke? Blue, white, black?
Old 04-28-2006, 08:26 PM   #21 (permalink)
it's white, which makes me worry it's oil, and i guess i am being optimistic that it is running lean and not burning oil bad.
__________________
1985 4runner EFI
Concord, NC
Old 04-29-2006, 04:18 PM   #22 (permalink)
Uh oh. White smoke is water. Sounds like you may have a blown head gasket. Have you checked the coolant level and the condition of the oil? If the oil looks like coffee, your head gasket is blown. Plenty of info on this site regarding the head gasket replacement and parts.
Old 04-30-2006, 12:26 AM   #23 (permalink)
well when you say coffee, i assume you mean with cream? yeah, my oil comes out black (how i take MY coffee!). i'm leaning towards maybe more of a problem with the rings, but i don't know.
__________________
1985 4runner EFI
Concord, NC
Old 04-30-2006, 08:30 AM   #24 (permalink)
L33T35T 4Runner's Avatar
Send a message via AIM to L33T35T 4Runner
how many miles?
__________________
95 4Runner SR5 3.0l. V6 2 wheel drive baby!
31" Bridgeston Dueler A/T Revos. Downey 1.5 Coils. Doetsch MV-12 Shocks. Brembo Rotors. Performance Friction Pads. Pioneer head unit with 1 12" Pioneer woofer. XM Radio. RB Headlight Harness w/ Sylvania SilverStars
New to the family: 85 4Runner 22RE, 4x4, 5 spd, SFA. 31" BFG All Terrain T/A KOs, genuine Walmart seat covers, "Dual" stereo, XM Radio, RB Headlight Harness w/ Sylvania SilverStars. Onboard air. Has been seafoamed to hell
L33T35T 4Runner is offline
Old 04-30-2006, 03:44 PM   #25 (permalink)
Well, the best thing to do is a compression check. If one of the cylinders comes out low, squirt some oil down the plughole and take another reading. If the reading doesn't change, you either have a leaky valve or a bad head gasket.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
'87 22RE, starts & runs fine then dies after 10 min---2 codes rmacFJ62 86-95 Trucks & 4Runners 5 04-11-2007 04:03 PM
91 22re CEL codes TurboKH 84-85 Trucks & 4Runners 4 12-29-2006 03:54 PM
22re 85 vs 86 bajjer9 86-95 Trucks & 4Runners 7 08-13-2006 02:09 PM
Help Check Engine Cel codes Trans codes Brake codes NicksBlue934runner 86-95 Trucks & 4Runners 2 04-26-2006 05:35 AM
22re engine codes david in germany Maintenance & Repair Archives 0 07-31-2003 12:23 PM
2009 InternetBrands, Inc.
