84 Solid Axle rebuild..w/pictures :)
#63
Yes. Tre = tie rod end. Just make sure to count the amount of turns it takes to remove them so you know how far the old ones go on. I also replaced my steering stabilizer and shocks while I was at it.
#65
I'm working on my first SA/Knuckle rebuild. I bought an 85 ex-cab EFI, and the knuckles were leaking, so I knew I needed to do new seals. The bearings and races appear to be in good condition, so I had decided not to replace the wheel bearings. The top/bottom knuckle bearings/races also look good, but they were included with the knuckle set.
Should I take back the knuckle rebuild kit, and just buy what I think I need, or should I just go ahead and replace the knuckle top/bottom bearings as a matter of principle on a 29 year old truck?????
#69
The first or second time I did one of these SA rebuilds I did read about the hub and the spring and ball but in all the confusion of the rebuild I sorta forgot about it. As a result when I pulled the dial off the spring sent the ball flying into oblivion. I thought oh well how important can that stupid little ball be? After I got it all back together I turned the hub dial and nothing! I had to order a new spring and ball from Wabfab. That stupid tiny little ball kept my rig in the driveway for 3 days.
Yea it sucks but that thing is absolutely required to make that hub function.
#70
Totally dedicated fan of the Marlin kit with backing plate eliminator kit, but subbing in the TG Wipers.... 2 yrs nearly of some hard crawling and lots of dd'ing, and not a peep of grease or fluid seepage!
Dirty 30's and ARP studs have held up really well to some hard wheeling and the stuff not even budged a smidgen! ;-)
#73
I did not enjoy rebuilding the front axle but, I had the best help I could get and it is almost done.
Now I have a V-6 diff with a limited slip locker.
I have to wait for the back pain to let up some so I can go finish putting her together so I can move her in to and close the garage door for the night.
#76
Hey man I'm rebuilding a 84 axel for my runner that I'm building and I'm stumped on the shims for the steering knuckle preload. It came half ripped apart without the shims how would I go about figuring out how many to put in the top and bottom?
#77
Shims and preload
Just wanted to make a point about shims and bearing preload . When you replace bearings and races on anything where the preload is set by shims , using the old shims does not guarantee correct preload . This is due to differences in bearing manufacture as well as how well you set the race. The smallest bit of debris in the race seat or a burr on the face of the seat , etc will effect preload as will using new bearings in old races. ... it's good practice to check preload if you have removed the bearing race even if you plan on reusing the same race .... just saying
FS[GreatLakes]: 1984 4runnrer front axle syracuse ny
Dexter350k
03-07-2018 03:38 AM
