| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
84 runner dies at random???
__________________
1991 Toyota PU, 4wd, 5spd, 22RE..SOLD 1980 Yota PU LB 4x4 5spd (swap) 20R, weber carb bone stock..Sold 1984 4Runner, 4" lift, 33's and hopefully more to come |
#2 (permalink) |
Sounds more like a problem with the coil to me. Sometimes when they start going bad it will only show up when they get hot. It's not that expensive of a problem to troubleshoot. So even if thats not what it is you don't have alot in it. Either way it sounds like something that is only showing up when it gets hot.
Just my thoughts.
__________________
84 4runner 22r carb. One Owner |
#3 (permalink) |
Yes it will only die or shut off after I have been driving it and it is up to temp. I have to go tot he parts store today so I'll see if they have a coil.
__________________
#4 (permalink) |
I used to have this problem in my 83 4x4 pickup and it turned out to be the Fuel Filter..
__________________
88 4Runner SR5 V6 5spd FIPK, 4" Pro Comp IFS Lift Stage 2, Stainless Skid Plate, OME Steering stabilizer, 31x10.50's TRD Torsion Bars. Arb front, Kaymar rear Bumpers, MM SE12,000, Downey Clutch, Diff breathers, Black Magic Fan. Load Warrior. (sold STILL BUMMED ABOUT IT) 93 4Runner SR5 V6 5spd Bone stock with lots of Plans.... 166k |
#5 (permalink) |
That's what I changed first since it was easy and cheap and that did not fix it.
__________________
#6 (permalink) |
Ok so I bought a new coil and truck still dies once it is up to temp I am lost and getting pissed I am sure it is probably something simple but I can't figure it out.
__________________
#7 (permalink) |
You said it sounds like its coughing through the intake? If its back firing throught the intake then then you need to look at timing, carb adjustment, spark, idle speed...... tune-up?
__________________
My current: 1986 Toyota 4runner SR5 EFI 4cyl 2.4L 22RE 5-Speed 242,000 Miles 95% Stock __________________ (Still working on restoring her) My old: 1988 Toyota 4runner SR5 EFI V6 3.0L 3VZ-E 5-Speed 302,000 Miles All stock (sold)______________ (Was my fastest truck i miss her...) My old: 1989 Toyota 4runner Non-SR5 EFI 4cyl 2.4L 22RE Automatic 231,000 Miles (sold)______________ (was my quietest and slowest yota.) Last edited by Kiroshu; 10-25-2009 at 08:38 AM. |
#8 (permalink) |
My next step when I get some time off from work was to change out the cap, rotor, and plugs. I am leaning toward the carb since it is original. What would it be on the carb? should I think about rebuilding it?
__________________
#9 (permalink) |
If its original 84 carb i recommend rebuild....
__________________
My current: 1986 Toyota 4runner SR5 EFI 4cyl 2.4L 22RE 5-Speed 242,000 Miles 95% Stock __________________ (Still working on restoring her) My old: 1988 Toyota 4runner SR5 EFI V6 3.0L 3VZ-E 5-Speed 302,000 Miles All stock (sold)______________ (Was my fastest truck i miss her...) My old: 1989 Toyota 4runner Non-SR5 EFI 4cyl 2.4L 22RE Automatic 231,000 Miles (sold)______________ (was my quietest and slowest yota.) |
| Tags |
| 20r, 22re, dies, randomly, stalls, warm |
