84 pick up webber carb missfires at full throttle
Old 01-03-2017, 06:40 PM
84bryinw's Avatar
I have been working on a truck i bought checked timing new plugs wires cap and rotor cleaned up carb and new gaskets changed in line plastic filter but I still missfires when I get about 3/4 throttle to w/of. I haven't got to the filter at the tank yet and I noticed front drive line had broken at sometime pinching the hard lines under the cab could that be my whole problem
Old 01-03-2017, 07:43 PM
L5wolvesf's Avatar
IF (big IF) it is carb related did you adjust the float level while it was open? And, which Weber and is there a fuel pressure regulator going into it?
Also, which engine?
Old 01-04-2017, 05:59 AM
84bryinw's Avatar
It's a 22re no regulator yes floats were adjusted carbs 32/36 electric choke. I notice that the clear fuel filter only has maybe 1/8 inch of fuel at all times shouldn't it be full
Old 01-04-2017, 06:02 AM
84bryinw's Avatar
Was going to replace filter by tank and patch the hard lines that are pinched today see if that helps me out
Old 01-04-2017, 06:44 AM
L5wolvesf's Avatar
Can't say if no reg is your current problem but just about all Webers (DGs, DCOEs, etc) need a regulator set at 2.5 psi (IIRC).
The pinch at the steel line may be acting like a regulator.
On filters where I can see the fuel it usually seems to be 1/2 to 1/4 full when not running.
Also, beware of the clear glass filters, they look nice but the o-rings can deteriorate and cause problems (fire) - been there.
When you cleaned out the carb did you blow out ALL the jets and passages? Also, what was in the bowl when you opened it?
Old 01-04-2017, 07:46 AM
ZXT
ZXT's Avatar
I would say it depends on how crunched the fuel lines are; it wouldn't be acting as a pressure regulator, but rather a flow regulator. If it can only manage to keep the fuel filter 1/8 full I'd either say the flattened lines are restricting flow or you have a weak fuel pump. Is the fuel filter before or after the fuel pump?
Old 01-05-2017, 07:10 AM
84bryinw's Avatar
It is before the pump I traced the pinched lines to find its the vent and return lines. Previous owner has re_routed the main fuel line
Old 01-05-2017, 10:30 AM
84bryinw's Avatar
So far I've changed both filters tried another coil and igniter could it be the mechanical fuel pump? I guess I've never had one fail
Old 01-05-2017, 02:55 PM
Bingle's Avatar
Sounds to me like your best and cheapest bet is going to be getting a fuel pressure gauge on the line (close to carb). FPR and gauge combo would be best, but diagnosing what the problem is would be a lot easier if you knew what kind of pressure you were getting.
I have heard of people having their mechanical pumps loose pressure. They would still pump, but weren't up to the task when pressed.
Old 01-05-2017, 03:09 PM
ZXT
ZXT's Avatar
I would say it's the mechanical pump. They die from time to time, a lot more often than electric pumps. That would be a cheap place to start, but as Bingle said, a fuel pressure gauge wouldn't be a bad idea either.
Old 01-05-2017, 03:38 PM
L5wolvesf's Avatar
Just to be clear here you have a 22RE that was converted to a Weber carb correct?
Old 01-07-2017, 06:38 AM
84bryinw's Avatar
Yes it's an re motor with an offenhouser intake and weber. I guess I will try a gauge and regulator and go from there
Old 01-07-2017, 09:23 AM
L5wolvesf's Avatar
Didn't the RE engines have an electric pump?
Did you find debris in the fuel bowl and filter when you looked at them?
Old 01-07-2017, 05:08 PM
84bryinw's Avatar
Yes Its a 84 truck that they put the re motor in with the webber and intake. I bought regulator and gauge new ngk iridium plugs and it fixed my backfire. Guess the plugs fouled do to excessive fuel still have a slight leak around carb base it runs a Lil ruff at cruising speed but overall it's much better
Old 01-07-2017, 05:21 PM
L5wolvesf's Avatar
If the fuel pressure regulator is set a 2 - 2.5 psi and you still have a leak then you probably have another problem.
On a Weber you can over tighten things. The screws and any other screwed in part (jets etc.) should be snug but not heavily cranked down.
Old 01-07-2017, 05:29 PM
84bryinw's Avatar
Ten 4 ya I have a 1 peice adapter for carb to manifold the webber kit came with one base gasket so tried to reuse the one on the bottom but it's looking like I need to replace it i have the pressure set at 3.5 should I go down 2.5
Old 01-07-2017, 05:33 PM
L5wolvesf's Avatar
3.5 is way too much - 2.5 max. Yes a new gasket. I always kept a spare carb kit around when I had a 32/36 they're not expensive.
Old 01-07-2017, 05:35 PM
84bryinw's Avatar
I'll have to tinker on it tomorrow get a new gasket and turn down pressure see how she dose
