| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
5.29's with 33's? help
__________________
85 Pickup EFI 3" suspension, 3" body lift, on bald 33x12.5s 204,000 miles also 91 4runner v6 auto stock trying to sell |
#2 (permalink) | |
Mine doubles as a daily, so 4.88 is the only way for me.
__________________
Quote:
#3 (permalink) |
Hold on, let me search for you and I'll post up...
__________________
Logan aka: BBP Kiss my IFS. RB4R Life Member #2 THE ULTIMATE TOYOTA RESOURCE '86 4Runner SR5 22R-E 4" Procomp/Superlift/Rancho 9000x/BudBuilt skids. Downey Header/Magnaflow exhaust, Supra AFM. 315/75R-16 Baja Claws, 4.88's, TrueTrac rear. Rear disk kit/trans e-brake. Addicted Offroad winch bumper/MM 9000 Current pics '06 4Runner Sport 270/65R17 BFG All Terrain KO's |
#4 (permalink) |
thanks i looked but didnt find much
__________________
#5 (permalink) |
I ran 33s with the stock 4:10s with almost the same set-up as you. I ran around 60-65mph in 4th....never saw 5th....terrible gas milage when I went to 35s...haha. I would have much rather gone with 5:29s. I say this because my cousin has 5:29s in his with just a 2" body and 33s Amazing differance and the power is great on or off the road. rolls 70 miles per hour no prob.
__________________
My Mind Never Stops! |
#6 (permalink) |
i believe i seen somewhere that it's only like a 300rpm difference between 4.88's and 5.29's..
somethin like a 7% increase from 4.88's. just get em..you'll be fine..i'd rather be a little overgeared than undergeared..lol
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE 1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous "Its still a toyota man.. Dont deprive it of its capabilities.." "If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009 |
#7 (permalink) |
google is your friend
![]() search 'gear calculator" and this thing comes up: http://www.grimmjeeper.com/gears.html plug the numbers in to give you some real world numbers ![]() 10.2 seconds
__________________
~Robb '81 Trekker The B4Runner Build TREKKER Forum Mini FAQ/Misc Ideas Thread **TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others |
#8 (permalink) |
i liked my 33''s and 4.10's on the highway more than my 5.29's and 33''s, cant wait till i get 37''s.
__________________
1986 Toyota 22r Short bed Pickup | 33x10.5x15 BFG MT's nick |
#9 (permalink) |
I'll share my experience.
I had planned on running 33's and 5.29's... Having run my former 33's on 4.10's (which mind you wasnt that bad!) ... Then driving my buddies rig with 5.29's (turbo 22re) on 33's and 35's respectively.. And now me.. I run 37's and 5.29 gear sets with a 22R. I would NOT run 5.29 with 33's as a Daily Driver. Why? Holy annoying hell on the highway! You're going to be in the 3000 rpm range to get anywhere above 60mph in 5th gear. And starting from a stop..1st gear, second, third.. you're gonna be annoyed with how much more you have to shift, and quicker. To each their own of course! ... but the power difference isnt worth the annoyance of having to clutch all that more and high rpms on the highway.. which also translate into higher differential temps (not good for the bearings or ring and pinion).. What would be my reccomendation? Shoot for 35's... Realistically its only 1" more in circumference .. since most 35's really only measure out to 33" anyway... and run 5.29's. You'll love it. 37's are cool too
__________________
1987 Pickup, single cab, 22R, new head, 260 cam TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac. |
#10 (permalink) |
I'm running 5.29's and 33's and it's my DD. I run 3200rpms to hit 70mph.
I quite enjoy it
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns armor locked lifted heavy SOB broken front and rear swaybars My Profile.. |
#11 (permalink) |
I got 4.88 and 33s and on th highway doin 70 in 5th im around 2500 3000
#12 (permalink) |
It depends on how you are going to use the truck. I run 4.88's with 35's and it runs great. The engine has a few mods(cam, exhaust, Weber 38), and only once in extremely high winds did I really feel underpowered.
The guy that built up the truck also put a 4.7 in the transfer case, so I still have a very low crawl ratio. I rarely hit over 3000 rpm's unless I am downshifting into 4th for a large hill or I am late to work. With 33's and 35's and 4.88's or 5.29's, you are either going to be under or overgeared. That being said, I want to run 255/85/16's on my truck and see how it runs with that set up. |
#13 (permalink) | |
Not so. Stock, my truck came with 29" tires I believe, as did most of ours with stock 4.11 gears in the rear. To get the same effective gear ratio with 33" tires, you'd need a 4.6655 ring & pinion. So going 4.88 with 33s actually over gears you ever so slightly from the stock ratio.
__________________
Quote:
#14 (permalink) |
i'm running 33's with 4:56's and not finding any trouble.
__________________
'92 short bed, 4 banger 5 speed, 4"ifs lift, 4:56 yukons, v-6 3rds, 33's |
#15 (permalink) | |
Quote:
That's why I think a 255/85/16 with 4.88's would be perfect since they are taller than a 33, but not as tall as a 35. |
#16 (permalink) |
with 4.56 and 32s I burn 3500 RPMs doing 65MPH and with my 37s its almost perfect for highway but wouldnt mind 4.88s but wouldnt really need 5.29 unless it was a wheeling rig but thats what dual cases are for
__________________
81 Toyota 4x4: 22R, weber carb, long tube header w/custom exhaust, L45 4 speed, 4.56 V6 3rds, TG highsteer, RUF w/sky shackle, custom rear springs w/shackle, 2" BL, 32x11.50x15 BFG MTs on 15x7s(street), 37x13.50x15 DC FC2s on 15x8s(trail), ARB air compressor, KC lights, topper... |
#17 (permalink) | ||
Quote:
Ah, I gotcha. A 255/85/R16 is a 33.06" tire though. Not really a difference in gearing. If you can find some 255/90/R16s, that would be a 34.07" tire and the new gear ratio you'd need to have the stock effective gear ratio is ~4.83.
__________________
Quote:
#18 (permalink) |
Mathematically, a 255 shows to be only a hair taller than a 33, but most 33's are not even 33" tall. There is a good site that compared all of the available 255/85's to each other and then to a 285/75 and a 33, and some of the 255's are almost an inch taller than the others.
Here's a pic from the site: article here: http://www.expeditionswest.com/equip...bfg_mt_km.html I am trying to figure out what I need to put my Tacoma tire/rims, which have 255/85/16's, on my 84 to try it out. I think spacers will do the trick, and I will start a new thread with how they work. |
#19 (permalink) |
I run 5.29s on my 83 with 35's with no issue and my wife runs 4.88s on her runner with 33's the 83 runs about 2900-3200 at 65 and the wifes runs about that with the 4.88
#20 (permalink) |
I run 5.29s with 33s with a 22re. Although it has an auto. I wish it was geared lower
__________________
02 KLX300 Dual Sported (Daily Driver) 87 Turbo 4runner STOCK 85 4runner: Automatic marlin5.29 elocker rear end. Rola roof rack. 33" BFG KM2's Build Thread 87 4runner (parts) 95 4runner 2wd auto(sold) |
#21 (permalink) | ||
Quote:
__________________
Quote:
#22 (permalink) |
I've to 5.29's and 33's on my 84. Doesn't go on the freeway anymore. That being said, it rocks on the trail. I am planning on getting 35 or maybe 37 if I can scrath together the money.
__________________
Trail Truck: 84 regular cab 85 22r -- streetRV head, 261C cam, 2.5" flowmaster, lock-right in rear, 1" Wabfab BL, IFS brakes, rock sliders, diff breathers, Amsoil, dual cases, front rock lights, tube bumper, 33x12.50 BFG MTs, cryo'd 5.29s, RUF, 213k miles ---Currently: Misc ---Next: Front bumper Link to build-up: http://www.yotatech.com/f115/jmazoso...uildup-137611/ DD: 01 Tundra V8, 3" flowmaster, FIPK, JBA Headers 133K miles Last edited by jmazoso; 10-28-2009 at 09:26 AM. Reason: bad spelling (smacks forehead) |
#23 (permalink) |
Staff
I have 5.29s with 31s.... But it's the 3.0auto combo. At 65-70 I am at about 3k rpm
__________________
94 4runenr: all the good stuff....... 89 4runner: 3.0, Auto, 5.29 lockright f/r. 31x10.5 wildcountry ATs. 81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s pacific-crawlers.com For all your Trail-gear and HID lighting Solutions Needs check out yotaworks.com Online store coming soon :) |
| Tags |
| 33s, 410s, 4runner, 529, 529s, 94, gas, gear, gears, mileage, pickup, running, stock, toyota, w, yotatech |
