4x4 Will Not Engage
4x4 Will Not Engage
I took my truck out today 4x4 in the mud for the first time since I acquired it in 2015. It was my first time offroading so it was a fun experience but ran into a problem where the front wheels were not moving. This is what happened:
Thanks
- I locked the wheels manually.
- I shifted the t-case to 4L which I believe I was in 4L as the 4x4 light came on and I think I shifted as far as possible. Also, I believe I shifted in neutral but dont recall exactly.
- I got stuck in the mud which confirmed that the front wheels were not moving at all. So I had to be pulled out.
- Then my buddy got stuck on another trail and I attempted to pull him out but again the front wheels were not turning so I couldnt help.
- Afterwards, I had my buddy check that the drive shaft was spinning which it was. I also tried with the hubs in free mode (or regular driving) and the drive shaft was not spinning.
- I tried to do a burnout and the front wheels did not spin either.
- I struggled to get up some hills especially at the top so I switched to 4H to get more speed which worked but again the front wheels were not turning.
- FYI, I had the front axles serviced with a brand new parts from Marlin Crawler since it was leaking although one tire still leaks so I am not sure if that is related to the 4x4 issues.
Thanks
