4x4 Not Working!!
4x4 Not Working!!
Needing again guys. Bought this 85 sr5 4x4 xtra cab stock straight axle pickup with AUTOMATIC locking hubs that sat for 3 years. Got it running and driving down the road got home and wanted to check and make sure the 4wd worked. Got all 4 tires off the ground, shifted into 4 high in first gear, back tire spun but front did nothing. Shifted into 4 low, back tire spun slow but again, front did nothing. The front shaft was spinning. After I shut it off I took the plug off the front diff to make sure it actually had gears in it and it did. There are no vacuum lines going to it, just a nipple on the top passenger side of the differential. PO said the hubs were rebuilt before it was parked. Any clues?
After I took the hubs off they looked terrible grease was caked up and metal shavings everywhere but the axle shafts were spinning. Everyone says to just go to manuals so that's my plan
With the locking hubs on, in 4wd the front driveshaft is spinning but not the tires or hub. When I take the locking hub off the front axles turn fine. So that's definitely hubs?
Steezy96yota
07-06-2015 10:00 AM
