4:88 with detroit locker rumbles and shakes - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-12-2009, 09:58 PM   #1 (permalink)
Cool 4:88 with detroit locker rumbles and shakes
So i got a used third member for my 85 and it vibrates before it (disengages?) at speed above 50.
Tire pressure is good, driveshaft bolts are tight.
At speeds above 70 the truck starts to shake me outta my seat. Progressively louder thunder vibration at 80. Letting off the gas to coast it rumbles much louder then quiets.... suddenly... as if it disengages something.
Well it's a mystery and I'm getting ready to tear it apart... or just slap it up front and run my new open yukon geared 4:88 THIRD in the rear.
Thoughts or suggestions?
jpjonesin is offline
Old 10-12-2009, 10:18 PM   #2 (permalink)
myyota's Avatar
Did you have the vibration before you changed the third member out ?, what about the axle bearings, check those as well because if there bad that can cause a vibration. I wouldn`t recomend a detroit for the front if its a daily driver.
__________________
86 Toyota 4Runner
Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper.
myyota is offline
Old 10-12-2009, 10:27 PM   #3 (permalink)
No noise or vibrations before. But that was in a 4:10 third. So now far more rotations at high speed.
It's either
(1) bearings
(2) gear set
(3) detroit locker
Heard some stuff about the detroit acting funny by engaging and disengaging... so I downloaded the trouble shooting guide. Guess I gotta tear this thing apart and have a look at its guts.
Old 10-21-2009, 05:56 PM   #4 (permalink)
benwill1's Avatar
Did you slide the driveshaft apart?? If you did, it could be "out of phase". The only time the locker will make a differance is when turning, or if you have tires not the same height. I love mine!!
benwill1 is offline
Tags
3rd, 488, 4runner, detroit, lockers, member, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
