| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
4.88 3rds in a 85?
__________________
02 KLX300 Dual Sported (Daily Driver) 87 Turbo 4runner STOCK 85 4runner: Automatic marlin5.29 elocker rear end. Rola roof rack. 33" BFG KM2's Build Thread 87 4runner (parts) 95 4runner 2wd auto(sold) |
#2 (permalink) |
Staff
YES they will fit. Any Toyota third from 79-95 will fit
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#3 (permalink) |
Thank you once again Death Cougar
__________________
#4 (permalink) |
Staff
One thing tho, you will have to make sure the flange will match up to your drivelines. Toyota used 3 different bolt patterns on their flanges (hence the triple drilled flange Marlin sells) so before you install it, just check to make sure your driveline matches.
__________________
#5 (permalink) | |
Quote:
__________________
'85 Xtra Cab Knobbly tires and such things. |
#6 (permalink) |
Actually, you would want to rotate it either 30deg (for room to drill all three different patterns) or 45deg (for just two patterns)
__________________
'85 4runner, finally lifted.
Done milling my steering arms! http://www.pirate4x4.com/forum/showthread.php?t=548270 Working on DUAL-TRANNYS |
#7 (permalink) |
Staff
Yea, 90 degrees will get you to the next hole on a 4 hole setup
__________________
#8 (permalink) |
Why couldnt I use the tripple drilled flange that Marlin sells?
__________________
#9 (permalink) |
Staff
You can, but you would have to get the diffs rebuilt. Reason being the crush sleeve to set the pinion depth. Once you take it apart, you have to replace that crush sleeve of it can loosen up and KABOOM your diff is toast.
__________________
#10 (permalink) |
The rear from a V6 will fit but I don't think the front diff will work. I thought '86 and up were all 7.5" differentials up front (IFS)? An '85 has 8" front and rear.
__________________
1985 4Runner 1997 FZJ 80 2007 HDJ100 - DD |
#11 (permalink) |
??? Are you serious??? I have swapped/removed flanges on almost every 3rd Ive ever touched and never had a problem. Ive never even heard this before. Acording to what you say, if you even replace the dust cap, you have to rebuild the 3rd. Can you give a good source for this info?
__________________
81 Toyota P/U, 22R with GotPropane kit, wheelbase stretched 5", bobbed box, narrowed tube frame from cab back, full exo, tube doors, Warn 9000i, 36" IROKs,TR bead locks, 4 link front, 3 link rear, Fox 2.0 16" all around. Rear axle is shaved, trussed, V6 3rd, CroMo axles, 4.88, full spool, and disc brakes. Front axle is trussed, HP 3rd, 4.88, 30spline Longfields, and a lunchbox locker. Full hydro Howe desert series race pump(reworked by PSC), CroMo steering arms, 4.7:1 t-case |
#12 (permalink) |
So could I use 2 v6 rears?
__________________
#13 (permalink) |
Yes. That's exactly what you'll need. 2 rear diffs out of V6 Trucks
__________________
'85 Standard Cab 4.5" HD SuperLift Custom Winch bumper 33x12.50 Mud Rovers Lincoln Locked in the rear; running 5.29s DD's: '87 XJ and '91 Suzuki DR650s Wheel Responsibly, Don't screw it up for the rest of Us. . . ---------------------------------------------------- "Obama is an acronym. OBAMA = One Big Ass Mistake, America" - Thanks for the Quote Hayes |
#14 (permalink) | |
Staff
Quote:
Talk to any diff shop. Hell, call Northwest differential and ask them. If you UNBOLT the flange, you have to reset the pinion depth. Thats just common sense. In order to reset pinion depth, you need to replace the crush sleeve (or just install a solid spacer). Source? Again, NW Diff, Randys Ring and Pinion, any reputable shop, etc. Perhaps "rebuild the diff" was the wrong terminology used. But you cannot just simply replace with flange without the RISK (see Potential Problems) of damaging the diff.
__________________
#15 (permalink) |
Thanks grant 526.
And thanks again DC. Now I just have to find 2 factory 4.88 3rds
__________________
#16 (permalink) | |
Quote:
In the 3rds Im running now, yes I use the solid spacers because coming down hard on a rock would damage the crush sleeve, and screw up the pinion depth. But like I said, Ive never had any problems just taking the flange off and putting it back on, even on my street yotas. Never heard of anyone else having any problems either.
__________________
#17 (permalink) |
your a little off with you terminology, you wont affect pinion depth just by taking off the nut, pinion depth is determined by the shim in between the big pinion bearing and the pinion head, but taking off the nut and reinstalling it with out installing a new crush sleeve may affect pinion bearing preload, the only way the nut would affect depth is if it comes loose and allows the pinion to slide in/flop around
__________________
- Joe 1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks 1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs Last edited by superjoe83; 08-26-2008 at 04:42 PM. |
#18 (permalink) |
Can anyone confirm whether or not the flange off the v6 3rd member will bolt right up to my stock 85 driveshafts?
Has anyone personally done this swap?
__________________
#19 (permalink) |
bump
__________________
#20 (permalink) | |
Staff
Quote:
Sorry i was thinking bearing dust cap, not the cap thats part of the flange (flange and cap are one piece IIRC?) so you are correct there. FWIW, solid spacers are the way to go. Then there isn't any question of "did it hurt the sleeve or ?! And yes, you are right Joe, i mean bearing preload.
__________________
#21 (permalink) |
Ring Gear Clearancing
I don't know about the flange fitting, but I do know that you may need to do a little grinding on your diff to stuff that V6 ring gear in there. It's really not much, maybe a quarter inch.
When you pull your third you will see a groove in the diff for the ring gear, the V6 ring gear is thicker than on the 4banger, so you'll have to take an angle grinder to it. Don't go nuts, you'll just need to take a little bit off. You'll figure it out, it's not hard, but I just thought I'd pass along a helpful nugget of information. |
#22 (permalink) |
No ones put factory 4.88s in a 4cyl truck or runner?
__________________
02 KLX300 Dual Sported (Daily Driver) 87 Turbo 4runner STOCK 85 4runner: Automatic marlin5.29 elocker rear end. Rola roof rack. 33" BFG KM2's Build Thread 87 4runner (parts) 95 4runner 2wd auto(sold) Last edited by SpecialScottie; 08-26-2008 at 11:59 PM. |
#23 (permalink) |
I guess its possible that some are 1 piece although I've never seen one
__________________
#24 (permalink) |
Factory 4.88 diffs aren't easy to find and you need to find two of them. I can imagine that poses a problem for most with people.
The diffs will fit, trust me. Just find two of them and buy the gaskets for the diffs. You can then lay the gasket on your axle and see if you have to do any grinding. I just installed two TRD elockers in my 1985 and had to do quite a bit of grinding. It isn't difficult but you have to be patient. I'm pretty sure the drive shafts will bolt up but I'm not positive. The TRD elocker diff flanges worked on my 1985 and they are based on a V6 carrier housing. Good luck.
__________________
#25 (permalink) |
Thanks Wardamneagle. I was also thinking about going the TRD elocker route.
DId you wire them up or use the cable opperation? The factory 4.88s only came in 4runners from 90-93 correct? Were they in the 2wd also?
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 4.88 factory 3rds | 4rnr | The Classifieds GraveYard | 1 | 04-15-2008 09:12 AM |
| Looking for 3rds and Buckets | 91ToyTrck | The Classifieds GraveYard | 5 | 08-02-2007 08:12 AM |
| interchangeable 3rds | 88yotatruck | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 12-15-2005 05:24 AM |
| Got my 3rds | Cebby | 95.5-2004 Tacomas & 96-2002 4Runners | 35 | 03-19-2004 05:54 PM |
| 3rds | grpape | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-17-2003 11:20 PM |
