YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-27-2008, 11:58 AM   #26 (permalink)
I have a V6 diff in the rear of my '79 pickup. I took the flange off of my old diff and put it on the V6 diff. I know for a fact that the V6 diff has a crush sleeve. Here is what I did:
1. measure torque required to start gears turning on V6 diff before removing flange.
2. Install 79 flange on V6 diff and leave nut a little loose. Then slowly torque the pinion nut a little bit at a time (just a small fraction of a rotation on the nut each time).
3. Between intervals of tightening the pinion nut, stop to check the torque required to start the gears turning and compare to original number from step 1.
4. Keep tightening the pinion nut a little at a time until you have arrived at the original torque value.
5. Whatever you do, do NOT overshoot the original torque value because at that point you will have crushed the crush sleeve and put too much preload on the pinion bearing.
I'm not saying that this is the "correct" way to do this, but I saw this procedure described in a manual and it seemed to work ok for me.
As for what vehicles came with 4.88 diffs from the factory, any 95 or earlier truck or 4-Runner that had an automatic transmission and came with 31" tires from the factory should have them. Not sure if that includes 2wd.
__________________
79 longbed 4x4
03 4-Runner 4x4 (DD)
scottd is offline
Sponsored Links
To remove this ad, register today!
Old 08-27-2008, 01:46 PM   #27 (permalink)
grant526's Avatar
Interesting theory. But I would rather not deal with the flange and replacing the crush sleeve. It's easier to unbolt the driveshaft from the flange, slide it up slip-yoke and mark it (to assure you have it aligned correctly for balance when reinstalling). Then remove the lover part of the shaft. Match it up to the flange on the diff that's still sitting on the bench. If it matches up. Your in perfect shape! If not, rotate it 30 or 45 degrees, mark your holes and drill the new holes that match your driveshaft. Simple and relatively quick!
Then you ready to install the new diff. Be it now or later. Just make sure to reassemble the driveshaft in the same orientation as before.
And as a side note. If you remove a driveshaft from a vehicle and plan on reinstalling it on the same diff, index (make an alignment mark) on both the flange and the driveshaft.
__________________
'85 Standard Cab
4.5" HD SuperLift
Custom Winch bumper
33x12.50 Mud Rovers
Lincoln Locked in the rear
DD's: '87 XJ and '91 Suzuki DR650s
Wheel Responsibly, Don't screw it up for others...
grant526 is offline
Old 08-27-2008, 03:38 PM   #28 (permalink)
SpecialScottie's Avatar
Thanks guys. I cant wait to get this done.
Can anyone confirm which years the 4.88s came out of? 2wd too?
__________________
1st gen 4runner interior for sale here
87 Turbo 4runner STOCK
85 4runner Build Thread
87 4runner (parts)
95 4runner 2wd auto
SpecialScottie is offline
Old 08-27-2008, 07:34 PM   #29 (permalink)
Wardamneagle's Avatar
No way would I use one of those silly Downey cables. They are wired with an FZJ80 elocker ECU and switch....took me a while to figure out the wiring but it's fantastic. The only disadvantage to this route is you cannot lock just the front. It's either rear or both but that's fine by me.
Pics...
4-88-3rds-85-front-elocker-installed-1-small.jpg   4-88-3rds-85-rear-elocker-1-small.jpg   4-88-3rds-85-elocker-switch-1-extra-small.jpg
__________________
1985 4Runner
1997 FZJ 80
2007 HDJ100 - DD
Wardamneagle is offline
Old 08-27-2008, 11:21 PM   #30 (permalink)
Wow that looks awsome man
Are you running 4.11s?
__________________
87 4runner (parts)
95 4runner 2wd auto
Old 08-28-2008, 02:09 AM   #31 (permalink)
Would it matter if the v6 4.88s were ABS?
__________________
87 4runner (parts)
95 4runner 2wd auto
Old 08-28-2008, 04:21 AM   #32 (permalink)
No, they are 4.56. You can buy the TRD elockers in 4.10, 4.30 or 4.56. It's kind of nice to have everything set up from the factory with a 1 year warranty. Unfortunately the Hi-pinion elockers (93 to 97 FZJ80 models) only come from the factory in 4.10. Otherwise I would have gone hi-pinion in the front.
No elockers, to my knowledge, were or are available in 4.88.
__________________
1985 4Runner
1997 FZJ 80
2007 HDJ100 - DD
Old 08-28-2008, 08:09 AM   #33 (permalink)
It doesn't matter if the V6 3rd is ABS (mine is). There is just a small hole on top of the housing where the ABS sensor goes that you will need to plug (I used a freeze plug).
__________________
79 longbed 4x4
scottd is offline
Old 09-03-2008, 01:45 PM   #34 (permalink)
Quote:
Pics...
That is a sweet set-up! Sorry to hi-jack, but I have two questions.
1) So does that system use two of the same "e-locker ECU" that the Tacomas and 4-Runners use, or is it a single "e-locker ECU" that operates both diffs?
2) And do you happen to have the part numbers for that "dual" e-locker switch and ECU, or what years FZJ80 to enter for a parts search?
I am getting ready to retrofit an e-locker in the rear of my '85, and I will be installing a hi-pinion e-locker in the front some time in the next year or two. I would rather use the set-up you have, than to have two individual switches from a Tacoma or 4-Runner.
__________________
1985 4x4 Extended Cab, 22RE
BigO is offline
Old 09-03-2008, 06:36 PM   #35 (permalink)
That procedure works fine.....handy if you have to replace a pinion seal Factory 4.88 thirds can't be regeared to a different ratio because, the pinion offset is slightly different from other 8" (4cyl and V6) diffs and will only accommodate factory 4.88 (expensive!) gearsets......something to think about if you're planning to go to a bigger tire later on. Here: http://home.4x4wire.com/erik/diffs/ And by the way, I activate my front e-locker with a controller I built (using a schematic from Marlin's website) that uses two normaly open/closed relays and a DPST toggle switch and an LED to indicate locked.....it was easy (and cheap!) to put together and has never failed me. Just make sure to run the small vent tube up high enough to keep water out! ---------Hans
__________________
Redneck trapped in a brown man's body
Oatmeal is offline
Old 09-04-2008, 01:11 AM   #36 (permalink)
It only uses one ECU. The 80 series landcruiser ECU's control two elockers. You can use any FZJ80 elocker ECU and switch from (I think) '93 through '97. The switch and the ECU do not have to be from the same year. You need to get the pigtails for both (with a few inches of wire) or it's going to be very difficult to wire. This ECU will control either a hi-pinion or a TRD elocker. I used an elocker ECU and switch out of a '97, I think.
Here is my write-up on the wiring involved:
http://forum.ih8mud.com/79-95-toyota...cu-switch.html
__________________
1985 4Runner
1997 FZJ 80
2007 HDJ100 - DD
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
4.88 factory 3rds 4rnr Axles/Suspensions/Tires/Wheels 1 04-15-2008 09:12 AM
Looking for 3rds and Buckets 91ToyTrck Items Wanted 5 08-02-2007 08:12 AM
interchangeable 3rds 88yotatruck 95.5-2004 Tacomas & 96-2002 4Runners 0 12-15-2005 05:24 AM
Got my 3rds Cebby 95.5-2004 Tacomas & 96-2002 4Runners 35 03-19-2004 05:54 PM
3rds grpape 95.5-2004 Tacomas & 96-2002 4Runners 3 10-17-2003 11:20 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
