3 inch rough country lift roughhhh
Old 08-26-2016, 03:23 PM
mikeyd6789's Avatar
Originally Posted by dirtdobberoffroad
wow that is horrible! drive around with 200lbs against the tail gate from what I hear R.C. springs settle a lot! Remove that leaf until it settles then add it back to lift it a little.
Which leaf should I remove ?
Old 08-27-2016, 06:45 AM
dirtdobberoffroad's Avatar
From the look of your picture I would take out the 2nd leaf but that would make axle rap worse I think, if you take the third leaf out it would leave a very long space between the 2nd leaf down and the 4th. I am no expert maybe someone who has removed a leaf from said pack will chime in. I know in a issue of 4wd Toyota owner they removed a leaf from a set of tough country packs I would assume the two are of similar pack design.
FinallyOffRoad
03-10-2016 12:16 PM
Crazychris1871
02-16-2016 12:29 PM
Redrunner3g
01-30-2016 10:15 AM
Quick Reply: 3 inch rough country lift roughhhh
