22r heating up - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-21-2009, 02:44 PM   #1 (permalink)
Exclamation 22r heating up
I have an 85 sr5 4x4 ext cab. I recently just swapped a 22re out of an 89 in its place by converting it to carb. This engine has got hot ever since I put it in the truck. I have replaced the thermostat ran it without one replaced the water pump and even flushed the radiator. I dont know where else to look.
Symptoms are as follows.
-temp slowly climbs to normal position
-temp rises slightly above normal then drops back to normal(I think thermostat opening)
-from normal the temp will start to climb slowly til it gets hot
-will not heat up just idling but if i crack the rpms a little(2000) or so it will heat up
I have never let it get over the top part of the line in the normal mark Just wondering what degree this is and how hot can they get before I really hurt it.
wannagetrdone is offline
Old 12-21-2009, 05:58 PM   #2 (permalink)
Guys any imput would be a big help and much appreciated
Old 12-30-2009, 10:20 AM   #3 (permalink)
84Horunner's Avatar
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Hope this helps.
__________________
04 Tacoma - stock for now, future mods to come
84 4Runner Wagoneer Springs front, 63" chevy springs rear, 4.10s welded in rear, puked out 22R, 35 Mud kings
84Horunner is offline
Old 12-30-2009, 12:05 PM   #4 (permalink)
Travisfab's Avatar
replace the radiator
Travisfab is offline
Old 01-08-2010, 06:22 PM   #5 (permalink)
TORTIS's Avatar
Did you burp the system?
__________________
89 Truck X-tra Cab
LCE Timing Chain
LCE Header
31'' Maxxis Buckshot
4.88's built by ZUK(the mind reader)
Aussie Locker Front and Rear
63'' Chevy Springs
Marlin HD Clutch
Bilstein HD Shocks
2.5" Exhaust W/Dynomax Muffler
2-50 Watt Backup Lights
TORTIS is offline
Tags
22r, engine, heating, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
