22R Crank Pully Removal - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-09-2009, 03:36 PM   #1 (permalink)
Travisfab's Avatar
I've tried the starter trick, I've tried the rope in the cylinder, I am stuck!!! I need to remove 2 also. One in a motor out of the truck, and one in a motor in the truck.
It's the last thing I need to do to fire off my new motor
__________________
American Trailers
Travisfab is offline
Old 08-09-2009, 04:23 PM   #2 (permalink)
myyota's Avatar
Try putting the truck in gear, you should be able to break it loose then.
__________________
86 Toyota 4Runner
Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper.
myyota is offline
Old 08-09-2009, 04:48 PM   #3 (permalink)
Travisfab's Avatar
Put it in 5th, and still no luck. I dont have an E brake.
I may just give up on these LC pulleys for now and take it to a shop so that they can do the bitch work.
__________________
American Trailers
Old 08-09-2009, 07:30 PM   #4 (permalink)
sh0kk86's Avatar
use a bigger cheater bar? unless it was welded on it should come off
__________________
1986 Toyota 22r Short bed Pickup | 33x10.5x15 BFG MT's
nick
sh0kk86 is offline
Old 08-10-2009, 07:11 AM   #5 (permalink)
Travisfab's Avatar
If I use a bigger cheater bar the truck will still want to creep forward when it is in 5th. I may just give in and take it to a shop.
__________________
American Trailers
Old 08-10-2009, 07:48 AM   #6 (permalink)
Etype R's Avatar
Try rope in the first cylinder at top dead center?
__________________
1985 Toyota 4Runner - Full SR5 package - 4 inch lift - 35" tires
Etype R is offline
Old 08-10-2009, 08:05 AM   #7 (permalink)
83
83's Avatar
Mine came off in 5th gear, 4hi, blocks in front of the tires with small breaker bar. And when it broke loose my knuckles went right into the frame and I probably should have got stitches...
__________________
Zach
'83 Shortbed 4x4
L52HD
Rebuilt & Mostly Stock
83 is offline
Old 08-10-2009, 08:22 AM   #8 (permalink)
aalan's Avatar
I had the same problem a week ago! Borrowed 2 air compressors and an impact wrench. Broke 5 brand new craftsman sockets. What I did was buy a 6point IMPACT socket, 1/2 inch, and a piece of 3 foot conduit. Put 19 mm 1/2 in. socket and pull handle or wratchet on with engine at TDC/comp. Lay it to the right, or drivers side, then slide the conduit over the handle and lay it on the ground. Turn the crankshaft by hand until the pressure of the wrench stops it. Only an inch or two if that. Put in NEUTRAL, Then BUMP the starter until it breaks loose. If you don't have the heads off these engines, Then TDC is not important at this point. You can always put the bolt back on and turn the crank to find TDC. This was after 3 days of driving myself and everyone I new crazy. I feel your pain!
Hope this helps
aalan
aalan is offline
Old 08-11-2009, 10:03 PM   #9 (permalink)
I had the same issue. I used my starter and it worked great. Maybe keep spraying it with PB blaster for a couple of days or you can always try heat. Ive never tried heat on the crank bolt and it might be a bad idea? If the engine is out, you might try taking it down to a tire shop and use their impact wrench. I did that for an axle nut on an old vw, their impact wrench worked when nothing I had did.
__________________
1985 4Runner
"What do you mean WE.....Khemosavi!"
Jager is offline
Old 08-11-2009, 10:10 PM   #10 (permalink)
camo31"10.50"'s Avatar
if its in 5th gear..it wont keep creeping forward if you BLOCK IT IN THE FRONT..........
i always use the starter trick to take mine off...
get big cheater..slide it over the ratchet..have a friend hold it up against the frame rail on the driver side..BUMP the starter..and it WILL break loose......
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE
1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous
"Its still a toyota man.. Dont deprive it of its capabilities.."
"If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009
camo31"10.50" is offline
Old 08-11-2009, 10:17 PM   #11 (permalink)
olharleyman's Avatar
I did mine with a 1/2 snap on torque wrench in the off position laid it on the frame and hit the key worked the first time.
As for the one out of the truck your going to want to shock it not try to break it like normal.
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
88 stock 4runner
3.0 auto
for now
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Old 08-12-2009, 08:53 AM   #12 (permalink)
If the head is off and bumping the starter is not an option, you can purchase an adjustable, rubber-strap wrench (sort of like an oil filter wrench, only a/b $10). It worked great for me. I just wrapped the wrench around the crank pulley, tightened up, then put pressure on it in the opposite direction as I loosened the nut. I had to use some muscle but it worked great. Plus, it would've been easier if I had a helper to hold the wrench around the crank pulley.
jtbartholmey is offline
Tags
22r, 22re, 85, bolt, break, bump, center, crank, crankshaft, dead, hand, loose, starter, top, toyota, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
