Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
20R Expend Gas As A 6 Cylinders, Please Help!
I got a 4Runner 1987, it had a 22R-E before, so it broke and I bought a 20R carbureted engine. After setting up the engine I tryed two kinds of carburetors the OEM and the Weber 32/36, but it expend too much gas in both ways, more than the 22R-E, and it's have less HPs. I tryed few things for fix that, but still the same. Also I installed a gas regulator and a return hose to the tank. Is someone know how to resolve this issue, please help me how figure it out. My truck right now is not good in gas millage.
Thanks in advance, Starlux ![]() Last edited by Starlux : 08-15-2008 at 10:15 PM. |
| Sponsored Links |
#2 (permalink) |
are you still using the original EFI pump in the tank?
__________________
- Joe 1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks 1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 4300k Philips bulbs |
#3 (permalink) |
Yes, with a gas regulator and a return line to the tank.
#4 (permalink) |
that could be part of the problem, even with a regulator you may be over fueling the carb causing bad gas mileage, do you have a pressure gauge after the regulator?
__________________
#5 (permalink) |
No, I may have to get one. Right now the regulator is set on 4.5, but I'll be writting back when I get a gauge.
Thanks, Starlux |
#6 (permalink) |
I tried to use a low pressure regulator with a fuel injection pump and it blew the regulator. I'll bet you're getting way too much pressure to the carb
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2wd 20r vs. 4wd 20r | MHale | Newbie Tech Section | 2 | 08-03-2007 01:48 PM |
| 20r | 86toysr5 | 86-95 Trucks & 4Runners | 6 | 04-05-2007 01:31 PM |
| Dust off your gas guzzling Ford Broncos---gas prices forecasted to drop even further | Bob_98SR5 | Off Topic Talk | 14 | 09-06-2006 08:45 PM |
| Strong smell of gas...not exhaust...GAS! | vegascoug | 86-95 Trucks & 4Runners | 21 | 05-01-2006 07:45 PM |
