Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
2.5" pro comp leaf?
i have a 85pu, i want pro comp springs on it but my problem is i can only find 4" lift springs, i dont want 4" though. i know they have 2.5" leafs but i have never seen one for my toyota, i was wondering if anyone has 2.5 springs or if i can get springs for another vehicle that will fit mine. any suggestions will be helpful
| Sponsored Links |
#2 (permalink) |
I've never heard anything good about Pro-Comp myself. Skyjacker does make a 3" lift spring if you're set on using the stock hangers. If you're up for some fab work, Trail Gear makes 3" springs.
__________________
'85 Xtra Cab Knobbly tires and such things. |
#3 (permalink) |
I can tell you right now from my truck with the 4" Procomp lift you're not going to get a whole lot of flex out of them. Could be other factors regarding how my truck is set up... but you can see from the pic I have with the back passenger wheel in the air that there isn't much give. Once again could definately be other factors on how its set up... Just a newb here offering my 2cents.
__________________
(Old Toy) 1984 Toyota 4Runner with just enough lift and just enough rubber that a newb could roll it on a dirt hill... and thats exactly what happened! (New Toy)1985 Toyota Pickup Xtra Cab...Chevy 350 V8 From the crate/2 inch body lift (for the motor swap)/4 1/2 inch ProComp Suspension Lift/35x12.50r15 BFG AT's/Turbo350 AT/Edelbrock Performance Carb/K&N Air Filter/Heckethorn Steering Stabilizer/Performance Headers/Full Custom Exhaust/MORE TO COME... |
#4 (permalink) |
im not looking for too much flex, i wont be crawlin so much. more of a baja runner and dune runner.. so flex isnt a big factor...
#5 (permalink) | |
actually, flex is important on a baja setup too. if the springs are too stiff, you'll bounce over the whoops instead of letting the springs absorb them.
instead of springs, you might check into extended rear shackles.
__________________
Quote:
#6 (permalink) |
yeah i know its important thats why i wanted the pro comp ones not some crawler styles.. i need new springs on my truck cuz mine are frowning, there stockers
#7 (permalink) |
trail gear has three inch springs. and remeber springs settle so 2.5 is gona end up around 2 inch or less.
__________________
I Got Your Jeep Thing, Now It Hurts To Pee. MY 4RUNNER BUILD http://www.yotatech.com/f115/88wildrunner-build-125357/ |
#8 (permalink) |
ya im okay with that, heres the whole thing. my springs are frowning so i need new ones, i can only find the pro comp 4" thing is, i like my stock heighth and i dont wanna go up 4" cuz thats pretty tall.. so a 2.5 would be perfect
#9 (permalink) | |
go look at 4wheelparts.com and search. they may have something.
I picked up a set of 4" procomps for my runner for 100 each. they might have something your size.
__________________
Quote:
#10 (permalink) |
yeah the 4" is all i can find there too, i was just wondering if there was a 2.5 for another platform that would work with the pickup.
#11 (permalink) | |
Quote:
they dont have 2.5 but 2 you would probly like better if you like the ride height you have right now.
__________________
#12 (permalink) |
how are they? do you have any? and what style are they? just stock replacemnt or a baja style spring?
#13 (permalink) |
downey makes good stuff and they have good warrenties, they should be stock replacments i would give em a call if i were you, also heres another option. http://www.oldmanemu.com/store.html?...ax=10&start=21
old man emu stuff is also very high quality
__________________
#14 (permalink) | |
Quote:
__________________
1985 4Runner 1997 FZJ 80 2007 HDJ100 - DD |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| SURVEY: BFG M/T's or PRO COMP M/T's or PRO COMP XTERRAIN | T-A-Z-M-A-N | Tires & Wheels | 28 | 09-25-2007 01:21 PM |
| Anyone use Pro Comp 2.5" spacers? | 4what | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 08-30-2007 02:30 PM |
| 1993 4x4 Xtra cab 4" Pro Comp Lift on 33" Super Swampers | tacodriver | Vehicles - Trailers (Complete) | 5 | 09-09-2006 09:35 PM |
| broke a pro comp leaf spring | chasmc2 | 86-95 Trucks & 4Runners | 6 | 06-20-2006 05:27 PM |
| would a '93~'98 "pro comp" made pre runner bar fit on a '94 toy 4x? | EPICjurneez | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-06-2003 10:57 AM |
