1st Gen 4Runner: Clutch Releasing Super Late
I was down with an illness and my 4Runner sat for a month. When I finally got back in it I noticed that the clutch pedal now seems to have virtually no resistance in its travel. The clutch still disengages but it engages very late in its up travel.
This is new - it didn't use to feel like this.
Clutch master cylinder is 6 mos old and new Aisin. Fluid is full and there are no leaks anywhere in the system. Slave age is unknown.
Thoughts on how to troubleshoot or diagnose?
clutches usually fail in the opposite direction, in other words they engage too close to the floor.
have you looked under the dash? i think that there is a helper spring attached to the clutch pedal, that could have an effect on pedal resistance.
you mean that it engages up near it's normal resting position, when your foot isn't on it? that is an adjustable parameter.
The helper spring is there, I replaced it a while back when I did the clutch master cylinder. The pedal return action is fine -- this feels more like loss of hydraulic resistance.
I'll provide an update once I get the slave installed tomorrow.
Yes, you are correct. It's engaging very close to the full rest position.
foppert
01-08-2016 08:33 PM
Scatterbrain
01-07-2016 11:09 AM
