1985 Toyota Truck 22RE Intake Leak - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-13-2008, 10:53 PM   #1 (permalink)
Hi, on my Toyota MotorHome it won't pass smog most likely due to an intake air leak. I have never been able to use the carb spray test very well. So I decided to seal off every connection to the intake and use a vacuum tester to see if will hold.What do you think? I have also been testing the various components as I disconnect them from the intake. I found and fixed a bad oil dipstick leak. But there is also a leak I could hear down by the oil pan that I could not locate. And little bubbles from a bolt too down there. Should I work on this crankcase leak further or is a little leak ok? I vacuum tested the brake booster too it held. Right now I am waiting for a big cork to fit in the throttle body.I am also concerned the EGR might leak and also I tested the air idle control when hot and it passed air which it's not supposed to when hot, right?
Any ideas on intake leak finding I would appreciate. Thanks
I discovered the Auxiliary Air Valve has an o ring that seals the shutter. It was leaking alot of air, I think this was my main leak. Cool. So now I will make an effort to find the small crankcase air leak as well as try to pressure test the intake, I got the cork and it fits. Thanks
pcmentor is offline
Old 05-15-2008, 08:48 PM   #2 (permalink)
O2 Sensor stays at .15v at idle
I didn't try to seal the intake because the throttle valve probably would pass air, I may still try. It's driving me nuts though. The O2 sensor reads like the mixture is real lean or too much air. It will go up to .45V at 2500 rpm but as soon as it idles it goes down to .15V. Everytime at 2500 rpm for 2 minutes also the O2 code shows up. The pipe from the EGR is cooler than the plenum so I don't think it's leaking. I also slipped a piece of aluminum to block the EGR and no change to the O2 Reading. Does anyone know where else a vaccuum leak could be? I d/c the PCV hoses too with no increase in voltage.I may check the valves next has anyone done the valve adjustment on their 22re? Thanks
Also has anyone used a duty cycle meter before? I just got one and the injector reads 4% at idle and goes up to 10% at 2500rpm. Does this sound normal?
pcmentor is offline
Old 05-16-2008, 04:33 PM   #3 (permalink)
chuggins143's Avatar
Check the rubber boots between your throttle valve and the MAF, they have a tendency to crack and suck air... I've done a trail fix by wrapping a bag around the cracked area and bungy'd it before and after the crack, keeps it from sucking air and should get you through....
Good luck,
Chad
__________________
85 Toy PU @ +4", on 37's, flat bed, stretched to 120"+ WB, Marlin Crawler, 5:29's, open (Aussie Locker on the way!)/spool, crossover steering, doorless... most of the time!
yet another 85 - work in progress... rattling, but not rolling... yet!
87 Turbo truck... not running
chuggins143 is offline
Old 05-16-2008, 07:07 PM   #4 (permalink)
Thanks I checked visually and they seem ok. I am going to plug the plenum and vacuum test it. I may check the valve clearances too. I tried to put propane into a port but no change in rpm or O2 voltage. Very confusing.
pcmentor is offline
Old 05-27-2008, 07:47 PM   #5 (permalink)
Passed Smog Today
I was expecting to pay $200 to have it worked on but they wanted the smog report. So I went to do a pretest and it passed! It has a miss, I think the EGR system may need a look at. Thanks for the suggestions.
I adjusted the valves and cured the miss.
pcmentor is offline
Tags
1985, 22r, 22re, 4wd, air, auxilary, intake, leak, leaks, manifold, oil, test, toyota, truck, vacuum, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1985 Toyota 4Runner 22RE ATL zman2day The Classifieds GraveYard 9 10-23-2007 07:42 AM
1985 toyota 4wd truck problem pereirabass 84-85 Trucks & 4Runners 1 10-10-2007 11:27 AM
1985 Toyota truck winch option superman180 84-85 Trucks & 4Runners 2 03-22-2007 12:17 AM
1985 Toyota p/u 22RE Danno 84-85 Trucks & 4Runners 6 09-19-2006 03:30 PM
22RE intake manifold coolant leak -Please help... 95g ATL 84-85 Trucks & 4Runners 3 05-02-2006 04:58 PM
2009 InternetBrands, Inc.
