| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#101 (permalink) | |||||||
__________________
1984 Toyota 4Runner EFI swap TG 4" springs Marlin Crawler Dual Ultimate Crawler 39.5" Iroks Addicted Off Road 8 point cage Addicted Off Road front bumper Addicted Off Road My 4 wheel drive club http://www.rockfrogs.org Quote:
#102 (permalink) |
What did it take to make your square front driveshaft? cost wise? Did you adapt your front shaft for rear use as a double cardon?
__________________
Obama is an acronym. OBAMA = One Big Ass Mistake, America |
#103 (permalink) | ||
Quote:
Yes, I did use the stock front for the rear CV. I had it retubed with .120 wall. It cost me $120 locally here in Pueblo.
__________________
#104 (permalink) | |
Quote:
![]() Chinamans was a blast! The new rig works great, we will have to make a trip there sometime before CO4J. I talked to Cory and he's also down with running Blanca sometime this summer too. I'm in for some snowbashing whenever you guy's can make it up, so is Cory. If Rollins Pass doesn't work we can always break some trail up here, there are a bunch of trails around here that don't get a bunch of use (fresh tracks).
__________________
The new project and daily driver 86 Turbo 4Runner, The "Luxury Crawler" http://www.yotatech.com/f116/86-turb...-build-155840/ The old Trail Rig - RIP 85 4Runner, Bobbed, Dovetailed, 37's, Dual cases, the list goes on. http://www.yotatech.com/f115/85-4run...thread-134399/ |
#105 (permalink) | ||
Quote:
Yup, Chinamans is a must before August! This summer's Blanca trip will be awesome, we'll probably have 5-8 built rigs that'll walk right up the mountain ![]() I'm down for some fresh tracks, I don't care where The first part of April is always busy (daughter's B-day) and now my Saturday's are busy for the next 8 weeks (3-4 year old's soccer ). But I might be able to squeeze a Sunday run in.
__________________
#106 (permalink) | |
Quote:
__________________
#107 (permalink) | |
Big thanks to CUbuff4Runner and his dad's sheetmetal shop & tools for a killer set of sheetmetal / LED taillights to replace the constantly broken stock taillights
And just a couple garage shots of the 4Runner
__________________
#108 (permalink) | |
__________________
#109 (permalink) | |
More cage pictures!
CU Buff 4Runner wire wheeling the welds before paint We also cleaned up the floor with the wire wheel to get ready for some DIY Herculiner bed liner. Dash speader bar just barely cuts off the bottom portion of the guages. A pillar floor mount. All the floor mounts are .25" x 5" steel plate. B pillar floor plate. We tucked the B pillar hoop back to maximize space to get into the rear seats. C pillar mounts on top of the tubs to clear the big tires. Dash speader bar and an awesome grab handle. All the triangle tube gussets came out perfect! Rear view of the cage and the D pillar floor mounts. With the tailgate closed.
__________________
#110 (permalink) |
NICE Cage!!
I hope you never NEED it! Keep up the Progress, I've been following your build for a while! You've built a Nice Rig! Grant
__________________
'85 Standard Cab 4.5" HD SuperLift Custom Winch bumper 33x12.50 Mud Rovers Lincoln Locked in the rear; running 5.29s DD's: '87 XJ and '91 Suzuki DR650s Wheel Responsibly, Don't screw it up for the rest of Us. . . ---------------------------------------------------- "Obama is an acronym. OBAMA = One Big Ass Mistake, America" - Thanks for the Quote Hayes |
#111 (permalink) |
i cant wait to see how those new tail lights fit/look! very cool build up.
__________________
Wherever, Whenever, However...Tread Lightly! |
#112 (permalink) |
on your front spring hanger, I have two questions.
1. Are the original cross member and the new hanger just staggered to get the front axle forward? 2. How much lift did you get from that? I need to move my axle forward, but do not want to get much lift. I am happy with the height I have now.
__________________
#113 (permalink) | ||||
Quote:
Quote:
Quote:
2. I'm not certain on the amount of lift I gained from the spring hanger. I bet it was about an inch in the front. Gaining that inch helps with the caster as well. Let me know if you need any close up pictures, I'll be happy to take some. You'll also see it in person in a month at the CO4RJ July 31, Aug 1 & 2nd!! Don't forget
__________________
#114 (permalink) | |
Stock front cross member. 3 mounts on each side, super thin boxed tubing and some lightly tacked captured nuts from the factory 25 years ago. I added 2 more supports on each side. I cut 45 degree cuts on a piece of 2"x2"x3/16" square tubing. Drilled a 1.2" hole and welded a nut to the back. I then welded them to the factory crossmember. There was a dent in the frame on this side. Somebody filled the dent in the tubing with Bondo The 4 extra supports. 1/4" plate that fits in front of the factory crossmember. Welded in place. It's not coming off anytime soon. Addicted Off Road front bumper now bolts to the orginal 6 holes and my extra 4. Still need to replace that headlight Nice aproach angle!
__________________
#115 (permalink) |
that roll cage is sick!!!
__________________
~1993 4Runner~ 3in Rough Country Lift~32x12.50r15 Remington Wide Brutes~No Sway Bars~K&N Intake~40 Series Flowmaster exhaust~Warn Manual Locking Hubs Futue Mods 3.4 Swap~SAS~Leaf Spring the Rear(Undecided)~Dual Case~Body Armor/Exo Cage~Sterio System~Lockers Front/Rear~BFG M/T or Goodyear M/T 35x12.50r15 Other Transportation Custom Fit BMX 1989 Foxbody 300k on it.(Still spin 2nd) 2004 Dodge Ram1500 5.7 Hemi |
#116 (permalink) |
nice job, great pictures give me some ideas on my truck.
Big thanks..............
__________________
God created police officers so firemen could have heros. It may be a summons to you, but it's therapy for me. 1987 Toyota Pickup..replacing engine and frame with a 85 22r, 6 " lift, 35 12.50 15's Backup vehicle.... F-350 4X4 DRW super duty crew cab. Diesel 17 mpg. |
#117 (permalink) |
that cage is alot of work very impressed. ive got the same helmet as you! keep up the good work
#118 (permalink) | |
Quote:
Aaron brought the rig up to my shop for the cage build. It is one of my favorite cages that I have done. We really maximized the head room and still allowed the top to go on/off. Its about as tight to the top as possible and actually makes putting it on and off easier. Aaron needed that cage badly. Especially since his kids were starting to want to go with him.
__________________
Scotty http://www.addictedoffroad.com/ 970-420-4198 Toyota Winch bumpers on SALE! |
#119 (permalink) |
any pics of those tail lights in place yet?
__________________
#120 (permalink) | ||||
First major trip of the summer, Mt. Blanca (14,000 ft mountain near the Sand Dunes National Park). It was by far the worst wheeling trip I've ever taken. Everything that could possibly go wrong, did
![]() Let's start with the horrible rear end sound when I was leaving Pueblo. I was fully loaded with camping gear and I was getting terrible sounds out of the "rear diff" while acclerating in 1st & 2nd gear. I get talked into headed up anyways ![]() We get to Medano Pass and while headed uphill, the noise is killer. I end up getting towed over the pass and to the campsite. I decided to tear the rear end apart to inspect the rear diff. I find some marks on the carrier from the pinion. I then decide to swap 3rd members to put the "damaged" 3rd in the front and put the "good" 3rd in the rear. I then start to tear apart the front axle. I start on the front @ midnight and finally button up the front & rear axles @ 5:45am. Best part, the front "good" 3rd has the same pinion to carrier damage ![]() I get 45 minutes of sleep, take it for a test drive and no change, same nasty noise. Guess I'll wheel it until it breaks. We head up Mt. Blanca Jaws 1 Jaws 2 Jaws 2.5 Jaws 3 What the majority of the trail looks like! CUbuff4Runner then proceeds to shear the 3 9/16's studs that hold his passenger side high steer arm to his knuckle near the top of the trail (12,500 ft) We work on his rig for several hours and decide to leave it up there. We plan on driving my 4Runner back up on Sunday to fix his rig with my brother's D44 parts off of his Jeep back in Denver ![]() Waiting for my brother and dad to bring the parts to head back up the mtn. My brother drove up Blanca since I was tired of driving. The "rear diff" noise is horrible and I didn't think we were going to make it back up the mtn with 4 people in the rig and 300lbs of parts and tools in the back. The steering in my 4Runner is very very loose and I get to inspect. All 8 of my knuckle studs are loose and one is stripped in the knuckle. I tighten all of them and we're back up the mtn. CUbuff figures out what the noise is, it's my CV on the rear driveshaft rubbing the horseshoe crossmember Scotty from Addicted Off Road told me that it was close to rubbing when we were installing the cage 2 months before the trip. Man, I'm a bonehead and realize I swapped diffs and worked on it for 8 hours was a complete waste of time.We make it to CUbuff's rig and get it fixed. He then proceeds to roll his 4Runner down Jaws 2.5 ![]() Down Jaws 1 in the dark After many more issues on the trail, we finally get off of the trail and home @ midnight, 48 hours after our trip started.
__________________
#121 (permalink) |
Amazing build! Tons of pictures and detail.
#122 (permalink) | |
I added the small yellow LED for the turn signal rather than using a trailer taillight converter. I found out the small yellow turn signal doesn't show up at all during the day and I really need to use the big red LED's as the turn signals after all. I have the converter but didn't have the time to to wire it in before the trips this summer. The metal inserts actually fit pretty good until the passenger side one took some damage. But that's why they are on there. Rather than breaking, they get bent up. I can just push them back into shape. They don't fit perfectly like a real taillight but it gets expensive at $15-$20-$30 a pop replacing broken taillights.
__________________
#123 (permalink) | |
I needed a cheap project to work on since I don't have any money to start any big projects. I've been gathering stuff for rock lights for years (like 6
) and I figured this would be a great time to put it all together.I also wanted a fuse block to be able to add electrical components like a CB & additional 12v power sources. I decided to go with 2 6-port fuse blocks. I also bought an ABS plastic project box from Radio Shack to hold all the fuse blocks and relays for the lights. For lights, I have a pair of 6" KC lights that I plan on putting on the front bumper. I also have 2 sets of small 55w lights from Wal-mart that are designed to go on the front of a small car. They fit perfect in the places I wanted them. I want one set on the front bumper pointed down in front of the front tires and another set between the F&R tires along the frame. I also have a rectangle set of lights to point behind the rear tires. The 6" KC's will be on their own relay and switch. The 4 small rock lights in front and middle of the 4Runner will be on their own relay and switch. And the rear 2 lights get their own relay and switch. Onto the pictures! I plan on putting the project box with all the stuff in it on the left hand side. It will mount on the passenger side fender and on top of the shock hoop. I will have to relocate one thing. Top view of the box with the fuse block mounted on the sides, relays in the middle and all the wires running out of the side. Each fuse block has 8ga wire feeding it. The left relay is a 40a that feeds the front KC lights. The middle is a 40a that will run the 4 small rock lights and the right relay will run the back lights. The power & ground wires for the relays are 12ga and the wire for the switch will be 18ga. Pics of the side mounted fuse blocks. Plently of room to expand if needed. Close up of the relays and wires Front 6" KC lights that I got for free 6 years ago from a friend. They should work out fine on the front bumper. When I get some time, I will paint them black rather than the worn out chrome. I've got 2 sets of these small lights for the front and middle rock lights. Rear lights Overall shot of my tailgate work bench with all the wire, connectors, and other crap The battery jump box has been nice, I've been able to test my wiring before I put it in the truck. I tested all 3 relays and they all work as planned.I'm done with the project box, I now need to get it installed under the hood. mount the 8 lights and get some power wires ran to each of them. I hope to get it done this week before my wheeling trip next weekend.
__________________
#124 (permalink) |
nice work...that box looks great.
__________________
#125 (permalink) |
Aaron, it may be time for the 1wire GM alternator upgrade. Those rock lights are going to be a huge amperage draw. I remember my old EB had a stock 60amp alt similar to the stock Toyota one and with rock lights and headlights on it would kill the battery at idle. I upgraded to a 130amp and never had an issue again.
__________________
| Tags |
| 1984, 4runner, 84, cooler, firewall, fit, garage, install, muddin, psc, steering, toyota, tub, tubbing, wheelwell |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Ranski's 85 4Runner Buildup | Ranski | The Fab Shop | 82 | 08-23-2008 07:24 AM |
| 88 4runner buildup. awesomeness | wowza025 | 86-95 Trucks & 4Runners | 2 | 05-08-2008 01:03 PM |
| 88 4runner buildup. awesomeness | wowza025 | 86-95 Trucks & 4Runners | 2 | 05-07-2008 02:06 PM |
| My 1984 Toyota X-Cab Buildup | azredliner | 84-85 Trucks & 4Runners | 3 | 07-03-2007 12:08 PM |
| 86 4runner buildup | Jared Ajlouny | The Fab Shop | 76 | 01-13-2006 02:43 AM |
