wont start back fires out carb and exhaust - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-16-2008, 10:02 AM   #1 (permalink)
Send a message via MSN to yotasonly
i have a 86 4runner with a early 80s 22r it has a weber and header and everthing else is stock i replaced head gasket intake gasket exhaust and oil pan gaskets and timing cover gaskets the timing chain did come off but i put it back on correctly the motor went back together and it acts like it wants to start but then it starts back firing out carb and exhaust my valve timing is lined up correctly ignition timing is correct and i have spark compression is at about 150 psi in all 4 cylinders i re adjusted valves and fuel pressure regulator is at 2.5 psi still wont start with the same symtoms
any one know of anything else that could be wrong i am stumped any suggestions would be very appreciated thank you
yotasonly is offline
Old 03-16-2008, 11:25 AM   #2 (permalink)
rowdy235's Avatar
seen this before- timing
__________________
The Daily Driver:
1998 Tacoma | Regular Cab | 4WD | 2.7L | 5-Speed Stick | Mostly Stock
The People-Hauler
1988 Grand Wagoneer | SUV | 4WD | AMC 360 | 3-Speed Auto | All Stock
The Dump Runner
1982 Pickup | Regular Cab | 2WD | 22R | 5-Speed Stick | Custom Exhaust
FER SALE! http://www.yotatech.com/f108/1982-sh.../#post51229916
rowdy235 is offline
Old 03-16-2008, 12:10 PM   #3 (permalink)
DIHOWARD's Avatar
that's timing for sure, either you blew your timing belt or its just on wrong. re-check your timing marks.
__________________
2003 4RUNNER LTD V6
FUSION LIFT/COOPER ATR/CAI/MAGNAFLOW/IPF LIGHTS
DIHOWARD is offline
Old 03-16-2008, 12:47 PM   #4 (permalink)
rowdy235's Avatar
^ if its attempting to run, I don't think the chain is off. I'd start by shooting a timing light at it and adjusting the timing.
__________________
The Daily Driver:
The People-Hauler
The Dump Runner
rowdy235 is offline
Old 03-16-2008, 01:56 PM   #5 (permalink)
Jeenyus04's Avatar
your distributor is 180 off. I did the same thing on my rebuild.
__________________
85 reg cab s/b, rebuilt 22r, .040 over bore, engnbldr's crawler cam, no cat w/ flo-pro (was on it). tg 5 inch lift. 35 baja claws bright green paint, sliders, custom front bumper, miller rear locker --project--
02 dodge extended cab s/b, black sport, 24 vavle cummins, 35's, 4 inch exhaust, edge ez
Jeenyus04 is offline
Old 03-16-2008, 02:03 PM   #6 (permalink)
Island_Yota's Avatar
Ya same thing happened to my Volkswagen when the timing belt skipped forward because of a loose tensioner, chain is either slightly off(1 tooth?) or your distributor is 180 degrees off as said before.
Island_Yota is offline
Old 03-17-2008, 08:00 AM   #7 (permalink)
yep im an idiot plug wires were on wrong thanks for being nice and not calling me a dumbass
Old 03-20-2008, 12:49 PM   #8 (permalink)
brooklee1000's Avatar
Doh!!!
__________________
Toyota does it Better, Longer, Faster, Stronger.
brooklee1000 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
88 That wont start 4Runner_Rebuild 86-95 Trucks & 4Runners 2 03-09-2008 10:48 PM
91 4runner fires on ether but wont start deek7623 86-95 Trucks & 4Runners 22 02-11-2008 10:31 AM
Urgent: My yota Back fires shoes138 86-95 Trucks & 4Runners 10 08-15-2007 12:53 AM
Recently rolled 4-runner now it wont start, why wont it ?? gtpunk18 86-95 Trucks & 4Runners 22 01-24-2007 10:25 PM
wont start headhunter 95.5-2004 Tacomas & 96-2002 4Runners 8 02-02-2004 04:10 PM
2009 InternetBrands, Inc.
