YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-07-2008, 06:07 PM   #1 (permalink)
manuk's Avatar
vibration from 15-20 miles per hour
hey guys i've got this vibration coming from somewhere in my drivetrain, i just cant put a finger on it. it's only between the range of 15-20mph, and it happens both when i speed up and slow down right through that range. it's really bad when my truck's cold but never the less it still occurs when it's warm. as i speed up through first, i shift to second and as i release the clutch my whole truck damn near vibrates. also, the vibration seems to travel from the passenger side rear to right below the cab as the truck slows down and it fades away. ive got 2 new u joints in the rear, with a balanced d-shaft. any answers?
manuk is offline
Sponsored Links
To remove this ad, register today!
Old 10-07-2008, 06:12 PM   #2 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
check alignment, tires balanced, Wheel bearings maybe, steering loose?. Theres alot it could be but those are a couple to check! My buddy is having a similar issue with his 83 SFA in his 94 pickup. His is more of a death wobble though not just vibration
Post up the specs of your rig too!
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 10-07-2008, 06:13 PM   #3 (permalink)
The vibration could also maybe be the main bearing in the tranny going! That would easily cause a vibration in the drivetrain
__________________
Old 10-07-2008, 06:56 PM   #4 (permalink)
pepsibluefloat's Avatar
Send a message via AIM to pepsibluefloat Send a message via MSN to pepsibluefloat Send a message via Yahoo to pepsibluefloat
could be shocks too if you're getting some wheel hop
__________________
1988 4runner::SAS|3vze|A340H|5.29's|Aussie Front|LockRight Rear|Longfield axles/Hub Gear|4"Rear/3"Front springs|Marlin High Steer|Custom CV rear driveshaft from High Angle Driveline|Rear D/S shortened and made into front D/S |35" Goodyear MT/R
My 4runner n stuff
pepsibluefloat is offline
Old 10-08-2008, 02:40 PM   #5 (permalink)
manuk's Avatar
tires are balanced, not sure about the alignment. ya the steerings loose too but i just figured, hey its an old truck i didnt expect it to respond like a corvette. i wouldnt call mine a death wobble though (yet), but definetly a strong vibration. any way in particular to check the main bearing in the tranny?
manuk is offline
Old 10-08-2008, 02:57 PM   #6 (permalink)
how are the fluids in the diff/tranny?
__________________
1990 4runner SR5, 3.0 with 254K, 5-speed, 4.56 gears, , Rancho 9000's, 33X12.50's trxus mt's, rear lock right, 4" lift with lc coils in rear
Quote:
Originally Posted by 4rnr View Post
I have NOOO $$ Im a poor college kid I recently started working so I decided to SAS.
If I dont sas Ill just waste money on chili cheese dogs and beer then Ill be poor, fat, and STILL on ifs.
My build thread
http://www.yotatech.com/f152/904_run...thread-158746/
904_runner is offline
Old 10-09-2008, 06:57 AM   #7 (permalink)
push the clutch when the vibration starts and see what happens, if it vibrates at 15 -20 when it is just rolling(no load on motor) or clutch you may be able to isolate.
chuck308 is offline
Old 10-09-2008, 10:56 AM   #8 (permalink)
manuk's Avatar
chuck,
i have done that. the vibration is there even with no load on the motor. only thing is, as i release the clutch it vibrates also. but to answer your question, yes the vibration is there at 15-20mph regardless of whether or not im in gear.
manuk is offline
Old 10-10-2008, 07:39 PM   #9 (permalink)
that rules out parts of the drive train. Your vibration is a constant velocity component, drive shaft, front axel, wheel bearing, rear end etc. Keep searching, we'll keep ponderin'
chuck308 is offline
Old 10-10-2008, 08:29 PM   #10 (permalink)
manuk's Avatar
how do i know it is or isnt the tranny main bearing?
manuk is offline
Old 10-10-2008, 08:46 PM   #11 (permalink)
4Crawler's Avatar
One thing to try if so inclined is to pull the rear drive shaft and test drive in front wheel drive (lock the front hubs and use 4H). If the vibrations go away, it is likely the rear shaft, if not, then you have eliminated the rear shaft. One thing to check on the rear shaft is the phasing of the u-joints:
- http://www.4crawler.com/4x4/CheapTri....shtml#Phasing
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Vibration decelerating 25 miles per hour & lower spacoli 86-95 Trucks & 4Runners 7 12-03-2006 02:13 PM
vibration at 50 miles per hour dougm395 86-95 Trucks & 4Runners 4 11-04-2006 07:04 PM
Vibration occurs when braking while going 30+ miles per hour HenrySacto 95.5-2004 Tacomas & 96-2002 4Runners 8 10-18-2006 02:15 PM
Wheel Vibration above 65 miles per hour! Gerdo Newbie Tech Section 7 12-27-2005 01:31 PM
Vibration/Shimmy over 50 miles per hour...Need help?? ravencr 95.5-2004 Tacomas & 96-2002 4Runners 13 05-08-2004 01:54 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
