Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
vibration from 15-20 miles per hour
hey guys i've got this vibration coming from somewhere in my drivetrain, i just cant put a finger on it. it's only between the range of 15-20mph, and it happens both when i speed up and slow down right through that range. it's really bad when my truck's cold but never the less it still occurs when it's warm. as i speed up through first, i shift to second and as i release the clutch my whole truck damn near vibrates. also, the vibration seems to travel from the passenger side rear to right below the cab as the truck slows down and it fades away. ive got 2 new u joints in the rear, with a balanced d-shaft. any answers?
| Sponsored Links |
#2 (permalink) |
check alignment, tires balanced, Wheel bearings maybe, steering loose?. Theres alot it could be but those are a couple to check! My buddy is having a similar issue with his 83 SFA in his 94 pickup. His is more of a death wobble though not just vibration
![]() Post up the specs of your rig too!
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more. Might as well start reading this if ya want know more |
#3 (permalink) |
The vibration could also maybe be the main bearing in the tranny going! That would easily cause a vibration in the drivetrain
__________________
#4 (permalink) |
could be shocks too if you're getting some wheel hop
__________________
1988 4runner::SAS|3vze|A340H|5.29's|Aussie Front|LockRight Rear|Longfield axles/Hub Gear|4"Rear/3"Front springs|Marlin High Steer|Custom CV rear driveshaft from High Angle Driveline|Rear D/S shortened and made into front D/S |35" Goodyear MT/R My 4runner n stuff |
#5 (permalink) |
tires are balanced, not sure about the alignment. ya the steerings loose too but i just figured, hey its an old truck i didnt expect it to respond like a corvette. i wouldnt call mine a death wobble though (yet), but definetly a strong vibration. any way in particular to check the main bearing in the tranny?
#6 (permalink) | |
how are the fluids in the diff/tranny?
__________________
1990 4runner SR5, 3.0 with 254K, 5-speed, 4.56 gears, , Rancho 9000's, 33X12.50's trxus mt's, rear lock right, 4" lift with lc coils in rear Quote:
My build thread http://www.yotatech.com/f152/904_run...thread-158746/ |
#7 (permalink) |
push the clutch when the vibration starts and see what happens, if it vibrates at 15 -20 when it is just rolling(no load on motor) or clutch you may be able to isolate.
#8 (permalink) |
chuck,
i have done that. the vibration is there even with no load on the motor. only thing is, as i release the clutch it vibrates also. but to answer your question, yes the vibration is there at 15-20mph regardless of whether or not im in gear. |
#9 (permalink) |
that rules out parts of the drive train. Your vibration is a constant velocity component, drive shaft, front axel, wheel bearing, rear end etc. Keep searching, we'll keep ponderin'
#10 (permalink) |
how do i know it is or isnt the tranny main bearing?
#11 (permalink) |
One thing to try if so inclined is to pull the rear drive shaft and test drive in front wheel drive (lock the front hubs and use 4H). If the vibrations go away, it is likely the rear shaft, if not, then you have eliminated the rear shaft. One thing to check on the rear shaft is the phasing of the u-joints:
- http://www.4crawler.com/4x4/CheapTri....shtml#Phasing
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Vibration decelerating 25 miles per hour & lower | spacoli | 86-95 Trucks & 4Runners | 7 | 12-03-2006 02:13 PM |
| vibration at 50 miles per hour | dougm395 | 86-95 Trucks & 4Runners | 4 | 11-04-2006 07:04 PM |
| Vibration occurs when braking while going 30+ miles per hour | HenrySacto | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 10-18-2006 02:15 PM |
| Wheel Vibration above 65 miles per hour! | Gerdo | Newbie Tech Section | 7 | 12-27-2005 01:31 PM |
| Vibration/Shimmy over 50 miles per hour...Need help?? | ravencr | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 05-08-2004 01:54 PM |
