YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-30-2008, 11:38 PM   #1 (permalink)
rowdy235's Avatar
Vibration
Okay, this has fooled everybody I've talked too, but it seems it must be simple.
Vibration starts at ~30 miles per hour and continues to ~45 miles per hour. Not very violent but you can notice it easily. Every part of the truck shakes, I feel it everywhere.
Thought it was a miss in the engine cause pressing the clutch caused it to stop. Then I realized pressing the clutch caused the truck to slow down and that stopped it. Speed up and press in the clutch and it vibrates
Thought it was tires. Took them to schwabs and had them rotated. They checked them and told me they were in balance. All inflated to 34 psi cold (per door jamb).
Any ideas? I don't want to pay $$$$ to have a tech look at it.
__________________
Daily Driver: 1982 Toyota Pickup Base 2WD 22R, TRD Cam,5-sp Manual, Toyota Truck Nation High Miler- 300k+
MPG: 25/32
Off-roader: 1990 Honda H3011SA Riding Lawnmower, 11hp OHV engine, Carlisle SNOW-HOG Tires
MPG: 1 Day of "Wheeling" per gallon
Come to the 2nd Annual Oregon Yotatech Meetup!
June 26-29, 2009: Browns Camp OHV Park
http://www.yotatech.com/f5/oregon-yo.../#post50902592
rowdy235 is offline
Sponsored Links
To remove this ad, register today!
Old 05-31-2008, 01:39 AM   #2 (permalink)
JCM4x89pu's Avatar
Send a message via Yahoo to JCM4x89pu
could be flat spots on the tires, or loose driveshaft components.. get underneath and see if there is any play in the joints.
__________________
1989 4x4 v6 pickup
****HUMMER RESCUE VEHICLE****
auto
251,872 miles.
driven hard like a toyota truck should be.
31 x 10.5 bfg at's, well taken care of 3vze, rebuilt Hi-Track IFS, delrin/teflon composite control arm bushings, redesigned 25mm BJ spacers, manual hubs, cat replacement & 2.5" exhaust with flowmaster muffler. Marlin bumpers, e-locker mod, various engine mods. LCE headers, too many custom made mods to list.. she goes anywhere i point her.
JCM4x89pu is offline
Old 05-31-2008, 06:35 AM   #3 (permalink)
CJM
CJM's Avatar
Flat spots in tires, driveshaft out of balance, bent rim, trans tailshaft or stub shaft, or axle shafts..
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 05-31-2008, 08:15 AM   #4 (permalink)
zhillz's Avatar
If it was flatspots it would be throughout the the drive not just 30mph+ right? Do what CJM said and see if your rim is bent if not my money is on driveshaft.
__________________
MY FIRST TOYOTA BUILD
WTB:
dash that fits in a 82
lift springs or shackles
gears higher then 4.56
rear locker
ONLY IF YOU HAVE PAYPAL.
zhillz is offline
Old 05-31-2008, 08:19 AM   #5 (permalink)
4Crawler's Avatar
For bent rims or rear axle shafts, lift the rear end in the air on jack stands and run the engine at idle and let it turn the wheels (block the front wheels well). Hold a pointer up to the tire face and see if you get any radial run out. If so, move the pointer to the lip of the rim and repeat the test. If run out is found there, check the brake drum/hub and see what it looks like.
Other option is the rear driveshaft, see below for some tips:
- http://www.4crawler.com/4x4/CheapTri...FixingProblems
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 05-31-2008, 09:14 AM   #6 (permalink)
rowdy235's Avatar
thanks for the ideas guys I'll try them today
but Les Schwab checked the rims and didn't mention they were bent
__________________
MPG: 25/32
rowdy235 is offline
Old 05-31-2008, 10:40 AM   #7 (permalink)
Al's Chop Shop's Avatar
Send a message via AIM to Al's Chop Shop
i'd also start with a better inspection of the tires and wheels.... les schwab is pretty hit and miss when it comes to decent tech's. the other thing they do that bothers me is when balancing tires they don't remove old weights, they just keep adding more and more.
if your driveshaft has no play, try replacing your rear shocks. one may be bad.
Al
__________________
81 Toyota pickup - Hers
22r, 5spd, 4x4, longbed on 33's... awaiting custom rears up front w/ downey shackles, chev 63's out back double shackled and 36's...
79 Jeep Cherokee Widetrack "Kronk" - The Build
TBI350, SM465, NP205, Hydraulic clutch, Hydroboost, Custom aluminum radiator, Flowtech headers, SOA D44HD w/ Hi-steer, D60, 36" TSL/SX's, LED tail conversion...
91 Chevy K1500 - The Hauler
TBI350, built 700r4, NP241, awaiting 4" lift...
92 FJ80 Land Cruiser - Fate undecided
Al's Chop Shop is offline
Old 05-31-2008, 12:15 PM   #8 (permalink)
rowdy235's Avatar
hmmm another thing I didn't think of was I didn't notice this before I aired up the air shocks. Might try lowering the pressure and see where it goes
__________________
MPG: 25/32
rowdy235 is offline
Old 05-31-2008, 06:43 PM   #9 (permalink)
I'd take off the air shocks, you'll probably get rid of the vibration and get a lot better ride with even cheapo gas charged shocks.
91diesel is offline
Old 06-01-2008, 12:51 PM   #10 (permalink)
rowdy235's Avatar
no way, I love the air shocks. You can easily adjust them depending on your load.
__________________
MPG: 25/32
rowdy235 is offline
Old 06-01-2008, 04:39 PM   #11 (permalink)
slacker's Avatar
I have seen tires seperate internally .. what I would do is borrow , or use another set of tires and rims .. install them , and run and see if it eliminates the problem ..
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come .
84 2WD "hotrod" Intercooled 7MGTE
83 Trekker SR5
MY PAGE
2WD fourm I frequent
NEW Trekker forum
slacker is offline
Old 06-01-2008, 10:16 PM   #12 (permalink)
rowdy235's Avatar
hmm will try
__________________
MPG: 25/32
rowdy235 is offline
Old 06-02-2008, 06:52 AM   #13 (permalink)
ocdropzone's Avatar
didn't you just add a lumber rack on your truck? did you have anything on it? Just a shot in the dark but when I was working construction the racks on our work trucks played havoc with what ever aerodynamics the truck had.
only thing that I can think of since the other ideas have been mentioned...
__________________
~Robb
'81 Trekker SR5 B4Runner Build
'89 Tercel Project POS Gas Saver
'05 Camry 'Wife's curb destroyer'
'03 Tahoe Family Truckster/Tow Rig
TREKKER Forum
LINK TO ONLINE FACTORY SERVICE MANUALS
All Toyota Website Search Engine
Wheel Responsibly, Don't screw it up for others...
ocdropzone is offline
Old 06-03-2008, 08:07 PM   #14 (permalink)
82greenbeast's Avatar
Sounds like you driveshaft, I had the same problem, and i figured it would be alright for a little while until i could get my garage cleared out to fix it, and the front of the drive shaft dropped out while i was driving (30km/h), just make sure your bolts are good, and there is no play in your universals
82greenbeast is offline
Old 06-14-2008, 12:57 AM   #15 (permalink)
ocdropzone's Avatar
any luck narrowing down the source of your vibration?
__________________
~Robb
TREKKER Forum
Old 06-14-2008, 01:04 AM   #16 (permalink)
stormin94's Avatar
Try taking the mowing deck off.......
But if it's your truck you are referring to.....
I'm replacing my U JOINTS tomorrow(4Runner). And you're symptoms sound identical to mine. But I also have a Squeek at low speeds accelerating up hill, or getting up to speed, then when I hit about 20 miles per hour, the squeek stops, but the vibration starts, but after about 40-45MPH, all is quiet.
__________________
1994 Toyota 4Runner SR5 4X4
208,000 miles and counting
3.0 V6, 5 speed
14/19 MPG city/hwy(before 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 06-14-2008, 10:40 AM   #17 (permalink)
rowdy235's Avatar
well tried it with different wheels and tires and got the same results. Airing down the air shocks helped quite a bit, so I'm not as concerned about it now. Thanks for all the suggestions.
Oh, and stormin, the deck has not worked since 2004
__________________
MPG: 25/32
rowdy235 is offline
Old 06-15-2008, 09:04 AM   #18 (permalink)
I would go with bent rim or out of balance tire. I have the same problem with my nissan truck after I swapped over the tires from my 4runner. The wheels on the 4runner had worn a weight on the inside of the wheel from rubbing on the caliper when I swapped them over to the nissan the vibration only shows up in 4th gear at the bottom 35mph to about 40 something.
jodaddy is offline
Old 06-15-2008, 01:30 PM   #19 (permalink)
Quote:
if your driveshaft has no play, try replacing your rear shocks. one may bad.
Al
Never thought of that becuase my truck did the same thing, but i put new rancho's on it, hopefully she'll ride smoother since both old ones were *$#@#%. Hav't had a chance to drive it since though
__________________
RIP:
1985 4runner, 2" lift in shackles, had big plans for it before i snapped it in two =(
sold:
1982 yota 4x4 P/U, SWB, short bed, 4.37's, 6" skyjacker lift, 33"x12.5"R15 bf all-terrains on AM rims, K&N Intake and filters, 8.8mm wires and cap& rotor, magnaflow duals - headers back
Current:
1990 toyota 4x4 p-up, ext. cab , 3.0 v6 5-speed,
powder-coated frame, powder-coated rims, tint all around, rancho 9000's, good old cherry bomb, and soem 31" kumho meatballs
Old 07-13-2008, 05:06 AM   #20 (permalink)
toyota-erik's Avatar
Not sure if you ever figured it out but I will give my .02
The first thing, when describing a vibration (especially on the web) its important to mention the frequency of said vibration. You mentioned "vibration" and "shake" in the same sentence. To me, those are 2 different things.
A low frequency vibration would feel like a washing machine out of balance and would indicate something out of wack with tires, rims, rotors ect. A high frequency vibration feels kinda like a D.A. sander does in your hand, usually indicates a driveline problem. I would start with the rear drive shaft assuming the vibration is still there with the t-case in 2WD and the front hubs unlocked. A common problem are the slip-splines on the drive shaft. With the trans in neutral, try to wiggle the the shaft at the splines. If you get movement, its probably your problem. This would also explain why the problem goes away when coasting with the clutch in.
Im assuming you have checked your u-joints, but are they "in phase"? Out of phase u-joints would cause the vibration to come and go at different speeds.
__________________
81 Toyota P/U, 22R with GotPropane kit, wheelbase stretched 5", bobbed box, narrowed tube frame from cab back, full exo, tube doors, Warn 9000i, 36" IROKs,TR bead locks, 4 link front, 3 link rear, Fox 2.0 16" all around. Rear axle is shaved, trussed, V6 3rd, CroMo axles, 4.88, full spool, and disc brakes. Front axle is trussed, HP 3rd, 4.88, 30spline Longfields, and a lunchbox locker. Full hydro Howe desert series race pump(reworked by PSC), CroMo steering arms, 4.7:1 t-case
toyota-erik is offline
Old 07-15-2008, 04:18 PM   #
